Did you follow step 2 to upload the contents of the 'upload' folder to your server?
GIPHY for vB5 and vB6
Yes i did upload everything to the correct directories and installed the xml true admin and set everything in settings, but when i click the button that appears in editor nothing happens
Based from the error you posted earlier, it looks like you are caching the templates. Try disabling the cache and then enable it again by setting the "Cache Templates As Files" option in AdminCP > Settings > Options > Style & Language Settings to No and then save. Then set it back to Yes and save.Helpful? Donate. Thanks!
I was just at my forum, reading a thread where my members were manually posting GIFs and thought, "I wish vB had this feature built in. I wonder if Glenn has made anything like that yet?" And here I am. Glenn you are the best! Purchase coming shortly.
- Likes 2
Comment on Topic Starter Ribbon for vBCloudby glennrocksvbThanks for confirming the fix works.Yesterday, 08:20 AM
Reply to Topic Starter Ribbon for vBCloudby MitchSeems to have done the trick
TYYesterday, 07:40 AM -
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbI have updated the template code in the first post. Please try it again.Yesterday, 06:38 AM
