You need the GIPHY API key.
GIPHY for vB5 and vB6
Upload the contents of the "upload" folder to the vB root directory.Helpful? Donate. Thanks!
Originally posted by glennrocksvb View PostUpload the contents of the "upload" folder to the vB root directory.
You know i cant do that. I dont even know what FTP is. I have always paid you to do these things. I thought this was a simple Products and Hooks install. It didnt say anything about going into cpanel. Ill just have to pass man.I wanted this and had been waiting but i cant do this stuff. And im gonna pass on paying for install. I like the products i can install myself.
Not all products require just uploading XML files. Some requires uploading extra files to the server via FTP or cPanel. I can upload them for you for free. I'll do it shortly.
But it would be beneficial for you in the future to learn how to do this yourself. I think you're just afraid to try and learn new things but that's understandable. If you know how to use a computer, then it wouldn't be that hard for you to learn these things.
Done uploading. Check it out now.
Let's discuss it in email.
I applied for Production API key from GIPHY to remove the 10k requests limit on this site and they approved it! This is not required under normal conditions but if you think you will exceed this limit, you must apply for it.
If you need help applying the same, please let me know.Helpful? Donate. Thanks!
I have updated the GIPHY icon with a better contrast. I will update the mod shortly with this new icon.
If you've purchased this mod, you will receive an email notification once I updated the mod. But if you can't wait, you can download the new icon below by right clicking and choosing "Save image as..." or equivalent.
Then upload it to your server and overwrite the existing one at /images folder. Once uploaded to the server, you may need to clear CDN cache (e.g. Cloudflare), if any. You may also need to clear browser cache.
Or you could use a different filename for the new icon image, upload it to your server, then update the giphy_icon_path stylevar in the Style Variable Editor in AdminCP with the new filename. This doesn't require clearing the CDN and browser cache.Last edited by glennrocksvb; 09-26-2018, 01:09 PM.Helpful? Donate. Thanks!
Originally posted by GM Junkies View PostNeed a solution for Cloud.Helpful? Donate. Thanks!
Originally posted by glennrocksvb View PostIt requires running a server-side code to search the GIPHY server for GIFs but uploading a PHP file on the server is not allowed in vBCloud. The possible alternative I can think of is to deploy a remote server-side script via server-less architecture using AWS Lambda which lets you run code without provisioning or managing servers. AWS Lambda has free tiers which allows 1M requests per month. I think that's more than enough for searching GIPHY.
I have followed all steps from installation but getting an error as following:
Warning: include(.../cache/template/template609.php): failed to open stream: No such file or directory in /var/www/vhosts/xxx/httpdocs/includes/vb5/template.php on line 375 Warning: include(.../cache/template/template609.php): failed to open stream: No such file or directory in /var/www/vhosts/xxx/httpdocs/includes/vb5/template.php on line 375 Warning: include(): Failed opening '.../cache/template/template609.php' for inclusion (include_path='.:/opt/plesk/php/7.2/share/pear') in /var/www/vhosts/xxx/httpdocs/includes/vb5/template.php on line 375
And when clicking the giphy button no popup window shows (nothing happens)
Any idea whats wrong here?
Comment on Topic Starter Ribbon for vBCloudby glennrocksvbThanks for confirming the fix works.04-26-2024, 08:20 AM
Reply to Topic Starter Ribbon for vBCloudby MitchSeems to have done the trick
TY04-26-2024, 07:40 AM -
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbI have updated the template code in the first post. Please try it again.04-26-2024, 06:38 AM
