Within this week!
GIPHY for vB5 and vB6
This mod is now available for purchase! Check it out in the first post.
Did you configure the GIPHY settings?Helpful? Donate. Thanks!
It took me a few seconds to register and get a key code, not sure if that is required to work but I did it and mine is working perfectly. Hope that helps
Yes API key is required. I've added a note for that in the first post. Thanks for that feedback.
Comment on Topic Starter Ribbon for vBCloudby glennrocksvbThanks for confirming the fix works.04-26-2024, 08:20 AM
Reply to Topic Starter Ribbon for vBCloudby MitchSeems to have done the trick
TY04-26-2024, 07:40 AM -
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbI have updated the template code in the first post. Please try it again.04-26-2024, 06:38 AM
