Quote Selected Text Pro for Self-Hosted vB5
    Paid Mod Quote Selected Text Pro for Self-Hosted vB5
    Sometimes you only want to quote a portion of a post instead of the entire post when replying. This modification allows users to easily do that.
    This plugin is very useful for forums that want to have more precise and relevant quotes in their threads. It helps users to avoid quoting unnecessary or irrelevant text and focus on the main point. It also enhances the user experience and makes your forum more efficient and organized.
    • When you highlight a portion of a post, a Quote button appears next to it if you have permission to post to that thread.
    • Can quote comments not just replies. By default, vBulletin 5 does not allow you to quote comments.
    • Can quote multiple posts across different pages in a thread without losing the existing quoted text if the default AJAX pagination is not disabled by a third-party plugin.
    • Selected quoted text is automatically put into an existing post that you are currently editing (if any) and not into the Reply box. Otherwise, it goes into the Reply box.
    • Adheres to the "Allow Quote BB Code" permission system. If that permission is disabled for the usergroup the user belongs to, the user will also not be able to quote selected text.
    • Only compatible with self-hosted vB5 and vB6 but not with vBCloud. To get the vBCloud version, click here.
    Difference of Pro version vs. Free version:
    1. Pro version works on desktop, tablets, mobile and other touch devices. While the free version only works on desktop.
    2. Pro version is more efficient than the free version in terms of page load performance. Pro only loads the mod on Topic pages where it is needed. While the Free version loads the mod on all pages across the site.
    If you are logged in to this forum, you can try selecting or highlighting some text in this post and a Quote button will appear.
    Screenshots:
    Please see attached screenshots below.
    Click image for larger version  Name:	quote-selected-pro-vbcloud-desktop.png Views:	0 Size:	76.6 KB ID:	23291
    Click image for larger version  Name:	quote-selected-pro-vbcloud-mobile.png Views:	0 Size:	71.7 KB ID:	23292
    Click image for larger version  Name:	quote-selected-pro-vbcloud-quote.png Views:	0 Size:	60.6 KB ID:	23293
    • Added configuration options
    • Added Enable/Disable option
    • Added Usergroup permission option to use the mod by specified usergroups.
    • Initial version​
    Price:
    $20
    (branding-free)
    This mod is the Pro version of the free Quote Selected Text for self-download vB5.​
    Last edited by glennrocksvb; 10-31-2023, 10:09 PM. Reason: Added vB6 compatibility
    Wow, you made my day Glenn!
    I've been waiting for this code improvement two years.
    Thank you!
    ...bought
      Purchased and installed. This is likely one of the MOST USEFUL vBulletin 5 MODS of all time!
      Would it be possible (meaning 'easy-ish') to have this excellent MOD modified so that one can identify/select which Usergroups can use it?
        Thanks for the nice feedback! <3
        And also to your suggestion. I'll definitely consider that.
      Would you also consider modifying this MOD so one can select what Usergroups can use it?
      We utilize Paid Subscriptions to secure funds to keep our Forum (kubuntuforums.net) on the 'Net. We don't provide any tangible incentive for doing so. Making "premium MODs" available is something we can do, as long as the MOD has the ability to specify Usergroups.
      Thank you.
        Sure! I will do that.
      Done and released v1.1. First post updated and emails containing the download link have been sent to the customers who have purchased this mod.
        Purchased and installed. Works like a charm.
          Awesome! Thanks for your purchase.
        There appears to be a 'bug' which is best illustrated in the following three screenshots.
Name:	Screen Shot 2022-03-04 at 3.29.41 PM.png
Name:	Screen Shot 2022-03-04 at 3.30.24 PM.png
Name:	Screen Shot 2022-03-04 at 3.30.45 PM.png
        As you can see in the second screenshot, when highlighting the Code block content including the Code: block 'tag', the Copy Code button gets included. When clicking the " Quote button, the Copy Code button gets included, which shouldn't happen, IMO.
          I'll look into that. Thanks.
        Thank Youy so much Glenn, Purchased. I am really happy with your interest in Your releases about performance and seo.
        How could I change font colour via css?
        Update:
        I used this and it worked:
        #quote-661529 .b-post-control__label {
        margin-right: 2px;
        font-size: 2.2rem;
        color: #ffffff;
        But css not working on smart phone although I made it like this:
        .l-xsmall #quote-661529 .b-post-control__label {
          margin-right: 2px;
          font-size: 2.8rem;
          color: #ffffff;
          By default, the Quote button style is the same as the site's global primary button style. If you want to change it, then you should use the vb5QuoteSelectedTextByvBModsRocks_QuoteCtrl_btn CSS class that's assigned to that button to add custom style to it.
          .vb5QuoteSelectedTextByvBModsRocks_QuoteCtrl_btn .b-post-control__label {
              margin-right: 2px;
              font-size: 2.2rem;
              color: #fff !important;
          If you also want to change the hover color, then add this:
          .vb5QuoteSelectedTextByvBModsRocks_QuoteCtrl_btn:hover .b-post-control__label {
              color: #ccc !important;
          You should not use #quote-xxxxx in the CSS as the xxxx is the node ID of the post where the Quote button is located. Doing that will only apply the style to the Quote button in that post.
            margin-right: 2px;
            font-size: 2.2rem;
            Thank You so much, Brilliant!
              Any chance of doing this for vB6 hosted?
                Beermonster As listed in first post.
                  Hi!
                  I have already been using the free version for a few days and would like to purchase this pro version. But I want to know if it is possible to remove the "quote" button from the bottom of the messages line so that users can only use this quota system.
                  Can you help me?
                  Thanks so much!​
                    Yes it is possible to hide the Quote button in CKEditor. Simply add this custom CSS in css_additional.css template:
                    .cke_toolbar:has(.cke_button__quote) {
                        display: none;
                      Hi,
                      sorry but the code don't work... I see the quote button even after changing the CSS... see the image. ThanksClick image for larger version
