Quote Selected Text
    Official - Free Quote Selected Text
    Sometimes you only want to quote some text in a post instead of the entire post when replying. This modification allows users to easily do that.
    • When you highlight a portion of a post, a Quote button appears next to it if you have permission to post to that thread.
    • Can quote comments not just replies. By default, vBulletin 5 does not allow you to quote comments.
    • Can quote multiple posts across different pages in a thread without losing the existing quoted text if the default AJAX pagination is not disabled by a third-party plugin.
    • Adheres to the "Allow Quote BB Code" permission system. If that permission is disabled for the usergroup the user belongs to, the user will also not be able to quote selected text.
    • Works on desktop browser but does not work on tablets, mobile and other touch devices. Get the Pro version for touch support and other features.
    • Only compatible with self-hosted vB5 and not with vBCloud. To get the vBCloud version, click here.
    If you are logged in to this forum, you can try selecting or highlighting some text in this post and a Quote button will appear.
    Screenshots:
    Please see attached screenshots below.
    Download the zip file, uncompress it and upload the XML in AdminCP > Products & Hooks > Manage Products > [Add/Import Product].
    NOTE: If you are upgrading the existing installed plugin to a higher version, make sure to select Allow Overwrite > Yes when uploading the XML file.
    v1.0 - Initial version
    v1.1 - Fixed compatibility issue with vB 5.6.6 due to the new name card feature.
    glennrocksvb
    Founder/Coder
    Fast VPS Host for vBulletin: A2 Hosting & IONOS
    nice - works perfect
      I have tried to download the product and the file is not downloaded, tried with other products and same result. Are they no longer available? Regards
        The product is available. Don't you see the link to the attached zip file?
          just rolled this out... works awesome! a way cool mod, thanks Glenn
          good work sir
            i'm waiting modification of this product for 4.2.2
            you refer me to your website
            http://www.vbulletin.org/forum/showp...87&postcount=3
              • you highlight a portion of a post, a Quote button appears next to it if you have permission to post to that thread.
              • Can quo
              Cool
                nice work!!! thanks
                  Personally, after the "like" feature on forums, I think this is the second most useful feature for forums. Period.
                  Love it.
                  Horizon
                  Junior Member
                    Thanks
                    Horizon
                    Junior Member
                    Horizon!
                      Awesome mod! Bought you a cup of coffee!
                      Works great, Glenn. Enjoy a coffee on me!
                      I would like to add this mod to our Forum but I am unable to find Products & Hooks in Admin CP. Using vB Cloud 5.3.3. Any chance someone can direct me to its location? TIA
                        Products and hooks are not allowed in vBCloud.
                      Latest Topics
