I am trying to download the zip file but it keeps telling me "invalid file specified". Any ideas?
Quote Selected Text
It works for me but maybe because I'm an admin. I looked at the permissions for the regular users and I don't see anything wrong with the ability to download non-image attachments. Can someone else try and let me know if you encounter the same issue that Iamtdg is encountering?
I got it figured out. I have an ad blocker that was causing the issue. Thanks so much. This is an awesome mod and I appreciate it.Originally posted by glennrocksvb View PostIt works for me but maybe because I'm an admin. I looked at the permissions for the regular users and I don't see anything wrong with the ability to download non-image attachments. Can someone else try and let me know if you encounter the same issue that Iamtdg is encountering?
- Likes 3
This feature really rocks. I don't understand why such a useful feature is not part of the original vB?
But it looks like it is not working from my cellphone? Is it possible please to make it work also in a cellphone?
XF has this feature even more advanced and it works nicely also in the phone. Too bad I didn't know sooner about the sale and move of vB developers to XF, because that's where the real vB5 is and where I have to move too.Originally posted by glennrocksvb View PostDoing a long press to select text on touch devices makes a context menu appears and that doesn't seem to be cancellable.
Yeah, that's not exactly a workaround as I envisioned itOriginally posted by vB5user View PostSure is. Move to XF. You will thank me later.
It is hard but doable and well worth it. Look here all major vb forums migrating like the recent caravans to the us.
https://xenforo.com/community/thread...ms-list.87974/
The mod doesn't work in PM because it is dependent on the availability of the existing Quote button in the post footer. If the Quote button is not available, then the mod will not allow quote selection since it assumes that the logged in user has no permission to quote posts. Since there is no Quote button in PMs, the mod works as intended not to allow quote selection in PM.Originally posted by Glaudiar View PostThis product doesn't seem to work inside private messages, any workaround that ?
But it doesn't mean that the mod could not be updated to allow quote selection in PMs even if there is no existing Quote button. The question is, does PM show quoted text to be displayed as quote like in normal forum posts? If not, then allowing the mod to do quote selection in PM will be useless.
Thanks for that explanation !Originally posted by glennrocksvb View PostThe mod doesn't work in PM because it is dependent on the availability of the existing Quote button in the post footer. If the Quote button is not available, then the mod will not allow quote selection since it assumes that the logged in user has no permission to quote posts. Since there is no Quote button in PMs, the mod works as intended not to allow quote selection in PM.
I'm not sure I correctly understood that.Originally posted by glennrocksvb View PostThe question is, does PM show quoted text to be displayed as quote like in normal forum posts? If not, then allowing the mod to do quote selection in PM will be useless.
Currently, I don't understand why you can't quote (or precisely, why the quote button isn't there) in PM, since quoting is possible manually via the bbcode and quoting in PM isn't irrelevant since you on long PM you want to be able to access certain part of a message rather than the whole message.
On my board, apart from the users using Vbmessenger, PM manual quote are exactly the same as in threads.
How the plugin could be modified to work in PM, do you have a solution or was this just a thought (a good one !) ?
I'll check to see what it will take to update the mod to make it work in PM.
by glennrocksvbThat's the same thing. When you enable "Cache Templates As Files", it generates static .css files on your server. All your css are stored as...Today, 03:06 PM
by flohseHello Glenn, it does not work, at least not for me. Do you remember our problem with phrases in the mod "Blur Out Replies for Guests To Encourage...Today, 12:02 PM
by SnowhogThanks. That's the first thing I tried, and it had no effect. I'll chalk it up to an anomaly and call it good....Today, 10:48 AM
