Is this something that has to be installed on the cpanel? Or is it all done on the forum admin panel. Products and hooks etc?
vB5 Likes Summary
Both,
There is a core file folder you will need to add to your web directory.
Then through the admincp. There is a file you will upload in the product/hooks. At the bottom of that page is "add/import product link". Select that then navigate to where it is on your computer.
Then finish setting up in the settings/options/[vBMods.rocks] Likes Summary Settings
Easy to install, great instructions and the mod works well on vb 5.6.0
...but oddly only for admin on my site, not for super moderators or registered users.
Which permissions on the forum are required for this to work?
24 hours of hair pulling and I've found it.
Usergroup manager
Registered Members
User Reputation Permissions
Can see who liked a post - YES
If that isn't set for the users then no one sees it.
I bought a copy of this about a year ago, it works well, great code and a good feature to our site.
I just received an email saying:
We have released a new version of vB5 – Likes Summary (Branding-Free)!
Use the link below to download your items. This link may be used up to 5 times before it expires on...
and a link to fetchapp.com
Seems odd to get an email out of the blue, no mention of an update in this thread and Glenn is still MIA.
Anyone else get and installed it?
or is it a clever trojan from a hacked account?
am I being too paranoid?
I was equally suspicious given Glenn is MIA. I used an old phone to download extracted the files and then copied the text to my PC to analyse.
It does look like an update, very few changes in the files comparing them
Function changed in the xml with a bit more CSS
v1.1:
- Fixed "Default Visible Users Count" setting of 0 to correctly show ALL users who liked a post.
- Initial version
- Likes 2
This is a wonderful plugin. Thanks.
Suggestion: I loved the display all feature, so any poster can see all the users like their post. When the user list is getting bigger and becomes longer. Is there any way to collapse the list, and display only 5 to 10 users? When you want to see the whole list, just click "display more" to see the completed list.
Thanks pecky I just got a chance to have a good look. The nice thing is that it's only the XML file needed for the v1.1 update, not the PHP. If I had have realised that I would have been less suss.
Installed well on VBull v5.6.4, takes a mighty long time after you upload the XML but eventually it completes and works well. I have noticed the last post in the thread won't show the usernames of the people that liked it but that's a minor hiccup, clicking on the number of likes still shows the list.
Thanks to Glenn or the code fairy that emailed the update to the registered users.
glennrocksvb i purchased this module and installed but like summery is only visible to forum admin none of other user groups can see that .how to fix that ?
See post #35 above
This is a much-requested vB5 mod to display Likes Summary for every post instead of the default functionality where it just displays the number of users who liked a post and you have to click on it to show the list of users. This plugin is very useful for forums that want to encourage user engagement and appreciation. It helps
He said in the next post he figured it out. The permission is also mentioned in Feature #3 in the first post.
I just now edited the user.php file. We have a BANNED 'new' user showing in "Welcome to our newest...Today, 08:22 AM -
Reply to Request: Instagram Media Embed or Retrieval Mod for vBulletin Forums Using Snapinstaink Approachby glennrocksvbThank you for the suggestion. I took some time to evaluate the request further and review Instagram's Terms of Use.
I understand the use...Yesterday, 12:05 PM -
I am running a vBulletin forum for a content creator community and wanted to raise a mod request around Instagram media integration. Currently when members...Yesterday, 09:14 AM
