This mod adds a topic pagination in forum display feature to your forum. It shows the page numbers of each topic in the forum channel page, so you can easily jump to any page of the topic.
This plugin is very useful for forums that have topics with many pages and users who want to access specific pages quickly and conveniently. It helps users to navigate the topics more efficiently and effectively. It also enhances the user experience and makes your forum more user-friendly and organized.
Go to this forum display page on this site.
Instructions:
v1.5
v1.4
v1.3
Price: $20
- Displays the same number of pagination buttons as the topic page itself does. Except of course it doesn't (need to) have the Previous and Next buttons.
- The number of pages displayed can also be controlled in AdminCP > Settings > Options > General Settings > Number of Pages Visible in Page Navigator which is an existing vB setting. This setting controls how many pages are visible on either side of the current page and controls both the pagination inside a topic (default vB5 feature) as well as this mod.
- This mod also respects the user-level setting for number of posts per page in User Settings > Account > Posts Per Page. So if a user chose 40 posts per page in his user settings, then the pagination buttons in each of the topic will display based off this 40 posts per page setting instead of the default 15 posts per page.
- Compatible with vB5 and 6 (self-hosted)
- Not compatible with vBCloud.
Instructions:
v1.5
- Fixed compatibility with vB 6.2.1.
v1.4
- PHP 8 compatibility fix for deprecated implode() function signature.
v1.3
- Fixed conflict with our free "Redirect Topic Title to First New or Last Post Hook by vBMods.rocks" mod again. This issue was fixed in v1.1 but re-instroduced in v1.2. Thanks to user alfreema for reporting this bug.
- Fixed a bug where the pagination buttons displayed twice when switching to other tabs (e.g. Latest Activity) and then back to Topics tab. Thanks to user Fleiding for finding this bug.
- Fixed conflict with our free "Redirect Topic Title to First New or Last Post Hook by vBMods.rocks" mod. Thanks to user 420 for finding this bug.
- Initial version
Price: $20
