Redirect Topic Title to First New Post or to Last Post
    Official - Free Redirect Topic Title to First New Post or to Last Post
    This mod allows you to configure the topic titles in the topic list to redirect to:
    • First new post (default)
    • Or to the last post
    • Or to the first new post, if none, then to the last post
    Note: This mod is only designed to work specifically in Topic view which is used in Forum channel module (forum display page), Search module and Search Results module.
    Download the zip file, uncompress it and upload the XML in AdminCP > Products & Hooks > Manage Products > [Add/Import Product]. Configure the redirection settings by going to AdminCP > Settings > Options > Redirect Topic Title Settings.
    • Updated to support Topic view in Search Results module (e.g. Today's Posts page).
    1.0
    • Initial version
    glennrocksvb
    Founder/Coder
    Fast VPS Host for vBulletin: A2 Hosting & IONOS
    I'm trying this on v5.2.3 and when it is set to First New/If None then Last and click on a topic on the home page it takes me to the first post in a thread. Any suggestions?
    Thanks
      On homepage? The mod is only for the forum display page where it list down all the topics in that forum channel. For example, in vBulletin 5 Products and Extensions channel page here on this site.
        Yep, doesn't work on the home page, works great on the pages below that.
        Thanks
          The mod was only designed to work specifically in Topic view which is used in Forum channel module (forum display page) and Search module.
          I have tried to download the product but the files cannot be downloaded, it seems it no longer is attached to the first post. Could you be so kind to update it? Thanks
          Regards
            Don't you see the link to the attached zip file?
              works great for my forum.... 5.2.4 seems to work great. Thanks Glenn
                Hi Glenn. Nice mod.
                This is a global setting for entire forum? Or users can set yourself?
                Thanks
                  This is a global setting for all forums and not a user level setting.
                    jenda3
                    Junior Member
                    jenda3 It's possible to make it a user-level setting. I could customize the mod for your needs. Please let me know if you are interested.
                      Hi,
                      in our site this mod seems working in forumdisplay but not for search modules (New Topics, Recent Posts). How is it possible?
                      As specified in the Note, it only works in Topic view. You can set the view in Search Module in the module configuration.
                        D'you mean in Site Builder? Cannot find anything about there...
                          glennrocksvb
                          Founder/Coder
                          Yes. If you click the Pencil icon of the Search module, you can see the Edit Search Module dialog. At the bottom is the "View" option which is set to "Default" by default. Change it to "Topics".
                        • musicoff
                          musicoff
                          Junior Member
                          musicoff commented
                          It was "Topics" already. BTW, we solved editing hooks_title_newlast_post and now works even in Search Module.
                          Thanks!
                          glennrocksvb
                          Founder/Coder
                          What did you change? Is there a bug in the mod?
                        • musicoff
                          musicoff
                          Junior Member
                          musicoff commented
                          Our sysadmin added some jquery's selector (he knows what exactly) useful to find objects even in Search.
                        jenda3
                        Junior Member
                        I just made a poll on my forum about this. The opinions are divided. So i am definitely interested in a user-level setting.
