Ok so that is a personal setting that has to be done by the user? No way to make it a default option? So nobody's age or birthday shows up in the profile view?
Profile Preview Tooltip (like Name Card but better!)
Yes it has to be set by the user. I'm not sure if there's an option in AdminCP to make it a default to not show birthday.Helpful? Donate. Thanks!
I will fix this and also make some improvements as well as make it work independent with the new Name Card feature introduced in vB 5.6.6. This mod is redundant with the Name Card feature so it's recommended to not enable them at the same time.Last edited by glennrocksvb; 01-22-2022, 12:34 AM.Helpful? Donate. Thanks!
Released v1.5 of this mod and updated the first post. I have re-opened the orders of all the buyers. If you are one of them, you should receive an email containing the download link for the new version.Helpful? Donate. Thanks!
Originally posted by Snowhog View PostDownload and installed (free, branded version). Works slick! Very nice. We are running 5.6.4.Helpful? Donate. Thanks!
Downloaded and installed Profile Preview v1.5 - Branded.
Alas, it doesn't work. ((
Forum version - 5.6.4
glennrocksvb,
Originally posted by glennrocksvb View PostAre you using custom style/theme? Can you try on Default Style?
I was deleting the old mod, installing a new one, still not working. This may be because deleting the old mod does not delete the template hook_profile_preview? How do I manually delete this template?
Originally posted by glennrocksvb View Postyou now have an option to display the profile tooltip via click or hover. Defaults to click
If you give me temporary admin access to your forum, i would take a look when I get home.
I logged in to your forum and you don't have "Profile Preview" mod installed in your forum. The only vbmods.rocks mods I see are "Add Custom Profile Fields in Postbit", "Full Width Logo" and "vBulletin 5 Quote Selected Text".
Originally posted by glennrocksvb View Postdisplays Profile About information as a tooltip when you click or hover an avatar or username link
I'll check. But even if you use click, there is a See More link in the tooltip to go to the Profile page.Last edited by glennrocksvb; 01-23-2022, 05:18 PM.
Reply to Quick Topic Moderationby glennrocksvbNice workaround darkboy245!
You can also accomplish this in a more proper way via PHP Hook using the hookFrontendContentAfterAdd hook. This...Yesterday, 10:18 PM -
by darkboy245I'm trying to give moderators the option to quickly lock a thread & an option to change the topic's prefix while replying to a thread, this is without...04-28-2024, 10:11 AM
Reply to Quick Topic Moderationby darkboy245I actually managed to create a button that will reply and also lock the thread simultaneously, it's not perfect but seems like it's working.
Code:<vb:if
Yesterday, 09:24 AM
