Add Posts to Bookmarks Plugin (with In-Feed Ads)
    Please check the server error logs to see detailed error messages related to the bookmarks plugin.
      Also check that the bookmarks table exists in the database:
      bookmarksthatrock
      Include the table prefix if any.
      • desmomax
        the table is there.
      #48
      How can i found the error in log? i tried search "bookmarks" or the error displayed but no results.
      thanx
        any suggestion glenn?
        I'm very sorry I can't use this app anymore.
          I'm investigating the issue and will get back to you.
            I found the issue. vB 6.2.1 made some database changes (as noted in the below announcement from vB) that introduced breaking changes to third-party plugins that rely on the previous database implementation.
            I will release the fix soon.​
              i will share a screenshot. Click image for larger version
                I have released v1.4 to fix compatibility with vB 6.2.1. Paid customers will receive an email containing the download link.​
                  thank you
                    fixed.
                    thanx
                      i fixed this mod and the other fix you just released.
                      when i do any admincp funcion ( for example update a product or moderate a new user) when done and system reload homepage i receive this error , do you see any relations with the other issue?
                      Click image for larger version  Name:	image.png Views:	0 Size:	712.9 KB ID:	34221
                        No, that's unrelated to the mods here. What seems to be happening is when it redirects, the /admincp directory is lost in the URL. To clearly see the issue, right click and open the settings in a new tab to get out of the iframe that AdminCP uses. Observe the URL, it contains /admincp. After making changes to the settings and it redirects, observe that the /admincp is lost in the address bar causing 404 not found error.
                        • desmomax
                          thanks glenn.. how can i fix it?
