Stop Links in Posts
    Originally posted by ayjayef View Post
    That works on this site. Spamtester posted a link in reply to this post and it's in the moderation queue. ayjayef didn't get email notification of a new post.
    I think you've fixed the quirk.
    Awesome! I will release the fix shortly.
      I have released v1.2 and updated first post. All the purchasers of this mod were emailed containing the download link to the new version. Thanks to ayjayef for reporting this issue. This was a good catch.
      • SpamTester
        On our site links in comments are sneaking through
        Enjoy the best canned meat meals using easy recipes and a variety of delicious, high-quality SPAM® meat. See what SPAM® Brand can do!
      #33
      I was just emailed the new version 1.2, installed, tested, FIXED.
      Great and super speedy work Glenn, thanks!
        Thanks for confirming the fix works on your site.
      #34
      Found a loophole Glenn (actually spammers on our site found a loophole)
      You can put a link in a comment and it's published.
      See post #35 above.
        I'll take a look.
        Maybe vB is not invoking the PHP hook in comments.
      #35
      See post #35 above.
      I found the issue. There are no PHP hooks when posting a comment. This is a bug on vB. I will create a bug ticket to them. I will create a temporary workaround while waiting for the official fix but it will require manually editing an existing PHP file. This means this needs to be re-applied after every vB upgrade. This is unavoidable since vB forgot to add the PHP hooks to the comments.
      This is one of those ¯\_(ツ)_/¯ moments.
        Bug ticket created. Please vote for it.
        • ayjayef
          +1 vote added. Thanks Glenn.
          Voted
          Thanks for the votes!
        #37
        Voted as well.
          Thanks for the vote!
        #38
        ayjayef, I have developed a workaround and installed it here. Can you please try it by posting a comment here using your test account?
          Spamtester has posted a comment with a link, it was moderated (good) and a thread subscriber ayjayef didn't get a notification (great).
          I think your patch is working well.
            Thanks for testing. I will release the fix shortly.
          #40
          v1.3 released and first post updated. Customers who have purchased this mod have been notified of this new version in the email.
          • ayjayef
            Notified, installed and tested as working very well.
            Was a little nervous editing ajax.php but as long as it's backed-up first it's not too spooky.
            Thanks for patching the vB bug till they do (hopefully in the next release)
          #41
          Not sure if it's vB quirk too but the link to the post in the Moderation queue takes you to the first post in the thread, not the offending comment message.
          [View Post] [Approve] [Delete] buttons all work fine though so it's not a "show stopper"
            I think it's a vB quirk. The mod does not have anything to do with generating the link to the post/comment in moderation queue. Was the comment in page 2 or more? You can confirm this quirk by manually disapproving a comment if it behaves the same.
            • ayjayef
              Thanks for the testing suggestion. Page 2 or more isn't a problem, seems vB will do this for any comment link while post links work fine. Another vB bug it seems.
              I confirmed the same issue on this site. vB is linking the first post for moderated comments. This is a vB bug.
            #43
            https://tracker.vbulletin.com/vbulle...sues/VBV-21050
            Thanks for your votes! This bug has been worked on and is now being code reviewed at the moment. It will not be included in the upcoming vB 5.6.7 though, based from this list of fixed tickets that made it to 5.6.7. It will probably be in 5.6.8.
              ayjayef and others, I can confirm that this bug is now fixed in the recent vB release 5.6.8. It is specified in the bug ticket and also in the 5.6.8 release notes.
              If you upgrade to vB 5.6.8, the manual edit you did for v1.3 of this mod is no longer needed. When you upgrade vB, the edited PHP file will be overwritten so there's nothing to do on your end for this mod to work. Please test this mod after upgrading to vB 5.6.8 and let me know if posting links in a comment will be detected by this mod.
                I found an issue on their bug fix for posting comments in https://tracker.vbulletin.com/vbulle...sues/VBV-21050. I informed them about it but unfortunately it didn't make it to the final 5.6.8 release. The effect of this is even if posting comment is successful, it will always report to all third-party plugins that it failed.
                They created a new bug ticket to address this issue https://tracker.vbulletin.com/vbulle...sues/VBV-21193 and hopefully they'll include it in the next release 5.6.9 or 5.7 (whatever the next version is)
                Due to this, I have no choice but to make a workaround fix on this mod to make it compatible with 5.6.8. Watch out for this.
                • ayjayef
                  Yes, I can confirm that vB5.6.8 still allows links in comments
                  I will send you a new update (v1.4) of the mod with the workaround so you can test before I release it to all customers.
                  PM sent.
                • ayjayef
                  I installed the update and it didn't stop links in comments (still stops links in replies though).
