This Post Footer Translate Button mod adds a button under each post to translate the corresponding post content into the user's desired language using Google Translate service. Even if your forum is using a language pack, we know that the user-generated content is not translated. This mod allows people who do not have English (or the forum's default language) as their first language to read and post in your forum using their native tongue.
This plugin is very useful for forums that have users from different countries and languages. It helps users to understand and communicate with each other better. It also enhances the user experience and makes your forum more accessible and inclusive.
The Translate button appears and works on all posts with post footer buttons - Topic page, Search Result page, and Activity Stream on Homepage and Profile page.
How to Limit the Languages in the Dropdown:
Add this custom CSS in css_additional.css template:
Update this part to add the language codes that you want to display. Follow the format of how each value is added.
To see all the available language codes, do the following:
Notes:
This mod is installed on this site.
Price:
$20 (Branding-free)
.postfooter_translate-container select option:not([value=auto], [value=en]) {
display: none;
- Right-click the languages dropdown.
- Click "Inspect".
- Expand the <select> tag.
- See the value for each of the <option> tag for each language.
- Take note of the language codes you want to show and add it to the above CSS code.
Notes:
- Google Translate has a limit of 5,000 characters (including newlines) to translate. If a post has more than this limit, then those exceeded characters will not be translated.
- Content inside [CODE], [PHP] and [HTML} tags will not be sent for translation because those are source code that should not be translated. The text "[Code here]" will be used instead as its placeholder.
- Since Google Translate page cannot be put inside an <iframe> tag for good reason (security), the translation will be displayed in a new popup window.
- For mobile devices, it may open the Google Translate mobile app if installed on the device. This is controlled by the device OS and not by the mod.
- Compatible with vBulletin 5 and 6 (self-hosted) only.
- Compatible with PHP 8+.
- Not compatible with vBCloud. For vBCloud version, get the mod here.
- Fixed an issue for vB6 where the post footer links were being hidden under ellipsis button even if all the links fit in one line.
- Initial version
Price:
$20 (Branding-free)
