GIPHY for vB5 and vB6 (Self-hosted)
    Mitch and I have successfully installed and set up GIPHY mod on his vBCloud forum.
    The cloud Giphy mod is working flawlessly on our forum. Thanks Glenn, for taking the time to implement it.
    Well Done Thumbs Up GIF by Team Coco
      I'm excited to announce that I have released the GIPHY for vBCloud mod:
      Make your vBulletin Cloud forum conversations alive and fun by allowing users to quickly insert animated GIFs from GIPHY.com, the top online source for the best and newest animated GIFs. No more combing the internet to find the right GIF to post and then hoping it has code to embed using [img] BB Code. No more saving GIFs to
      Happy Jimmy Fallon GIF by The Tonight Show Starring Jimmy Fallon
        I applied for Production API key from GIPHY to remove the 10k requests limit on this site and they approved it! This is not required under normal conditions but if you think you will exceed this limit, you must apply for it.
        Click image for larger version Name:	image.png Views:	1 Size:	32.4 KB ID:	13060
        If you need help applying the same, please let me know.
        The beta api key is now limited to 100 calls per hour. So I am interested in switching to a production api key. How difficult was it to get the approvement for a production key from GIPHY?
          I can't recall how long it took for them to approve my Production API key but I would say it was approved within a week. Be prepared to describe how you'll use the GIPHY API key and a video screencast of it in action showing the "Powered by GIPHY" attribution.
        • flohse
          Did you provide them a screenshot of the mod setup?
          Providing a screenshot is optional. Providing a video screencast on how the mod works is the one that's required.
          For the screencast, I think doing the same I did for the demo screencast in the first post is good enough to show how the mod works.
        #94
        I had submiited a request for a production API key. This request has been rejected by GIPHY with the explanation that the app does not meet their criteria. They think I would be fine using the beta key and I don't need unlimited requests. I provided a similar screen video like you did. Any suggestions?
          Maybe it would also help to provide the monthly user visits, number of users, posts, etc?
            Or maybe they got stricter on the production api key approval.
          • flohse
            Ok, I am just at the beginning. The number of posts and users may be the reason.
          #96
          Excited Despicable Me GIF
          Excited Despicable Me GIF image widget
            it working on my site with the standard api key, AndeRRail, its a new site, still a working progress ​
            • flohse
              What do you mean by standard api key, the development api key? This works but is limited to a fixed number of api calls per hour.
            • Dudedawg
              The non-production api, it just worked, I used the SDK issued api, this api is only giving you a 100 called per hour, if your website is very busy, you will have to apply for the production api,
              i meant the Production api
            • flohse
              I already asked GIPHY for a production key, but they didn't grant it.But right now there is no real need for a production key.
            • Dudedawg
              only if you are getting more than 100 posts in an hour, then there is no point, their requirements are set too high, I did the same, and blah blah blah, they denied.. oh well
            #98
            I want to define a secondary user group whose membership determines whether a user is allowed to use the GIPHY mod or not. To do this, I created a group called “GIPHY users” and set all permissions to “No.” After all, the relevant permissions are as far as I know overwritten by the primary user group when set to “Yes.” For this approach, mere membership in the “GIPHY users” group is all that’s required. The “GIPHY users” group has been allowed to use the mod.
            If I add a user from the “Registered User” group—who is not allowed to use GIPHY—also to the “GIPHY users” group as well, I would have expected that user to be allowed to use GIPHY. However, that is not the case.
            Does the GIPHY mod ignore the membership of a secondary user group?
            Btw. I have the same problem with the Shoutbox mod.​
              The mod only checks the primary usergroup. I will update it to also check the secondary usergroup.
              • flohse
                Hi Glenn, any update on this?
              Released v1.2 to add Secondary Usergroups option. Paid customers will receive an email confirmation containing the download link.
              flohse, please confirm if the Secondary Usergroups option works in the latest version. Once confirmed, I will add the same on other mods that have Primary Usergroups option. Thanks!
              • flohse
                Confirmed!
                Nicely done!
                Thanks for confirmation. I'll work on other mods.
