Topic Starter Ribbon
    Paid Mod Topic Starter Ribbon
    This mod adds a topic starter ribbon feature to your forum. It shows a ribbon badge on the posts of the topic starter, so you can easily identify who started the topic.​
    This is very useful for forums that have active and lively discussions with many participants. It helps users to follow the topic more easily and clearly. It also enhances the user experience and makes your forum more colorful and attractive.
    • Compatible with vB6 (self-hosted)
    • Compatible with vB5 (self-hosted)
    • Not compatible with vBCloud. For vBCloud version, the mod can be found here.​
    Screenshot:
    Click image for larger version  Name:	topic-starter-ribbon3.png Views:	1 Size:	58.5 KB ID:	6028
    See the gold Topic Starter ribbon at the upper left corner of postbit here on this topic.
    Notes for RTL: Change all instances of left to {vb:stylevar left} in the CSS and the degrees to 45deg (positive not negative).
    Price 1:
    $15 (with vbmods.rocks branding in the footer)
    Price 2:
    $40
    ($15 base price + $25 branding-free)
    What type of install is this? Some are easy for me. Others are not.
      It's an easy install. You just have to upload the XML file in AdminCP as described in the readme file included in the package.
        Looks good. Thanks.
          Originally posted by Fleet View Post
          Looks good. Thanks.
          Thanks for the purchase. The mod looks good on your site!
            complements, you are creating useful products but very high prices
              The branding-free version makes it seem like it is expensive. But, it is still much less expensive compared to others who charge $75 for the branding-free license alone.
                Don't forget the work behind making modules. Usually you have to know a lot of API-classes, DB-tables...and a lot more. Because there are a lot to know or search for it when you don't know. It is not only a 5 minutes job and done (even you know all the stuff allready). Writing the mod is not the end... You got free updates here for now... not usually. If vB is changing anything you have to fix it. And since now Glenn did it fast and good.
                I think the price is absolute ok. I would buy it if I didn't made it already by myself :-)
                Keep your good work rocking!
                My forum closed !
                  I will buy this maybe in october. But without branding free.
                  Branding is okay when it isnt massivly obtrusively. A small link is okay and i think it is nice for the developer
                    I also offer lifetime free updates for all my mods. While others have 3 license pricing (3 months, 1 year, lifetime). If I would do the same on my mods, the price for the lifetime updates would be around 3 times higher than the current price you're seeing now.
                      I hate 3 licence pricing. Its horrible and often so expansive. An if you buy 1 year, you get often only one update. I like it so how it is.
                        Idea:
                        Maybe u can add, that the background of the text, which written by the topic startern, has a different color as the others. this would be a nice combination. Not everyone take a look on the mini-profile.
                          Originally posted by Menderley View Post
                          Idea:
                          Hey hey, don't give away that much information :-) That is a part of my mod ... in a few weeks online
                          My forum closed !
                          • Menderley
                            whaaaat? I pull things out of your brain. Call me Magic big Mama.
                          XML Error: mismatched tag at Line 53
                          installation error Click image for larger version
                            I will look into it. Thanks for reporting.
                          Saiff, I've fixed the issue. You should receive an email containing the download link. Please download the product and install again. Let me know if you find any issues.
