Topic Starter Ribbon
    Updated suggested CSS changes in first post. Added change #2. Please see description for more details.
      I found a breaking change in the upcoming vB 5.3.4 version that breaks the CSS for this Topic Starter Ribbon mod.
      To fix this issue, change all instances of the code below in the custom CSS added for this mod:
      .vmtr-topic-starter #post
      with:
      .vmtr-topic-starter > .anchor
        I have added a new ribbon style and applied it here on this site. I will send the new CSS code to all those who bought this mod.
          Re-opened all orders to send the updated mod with the new ribbon style. It also includes the 5.3.4 fix. No need to re-install the XML file. Only the CSS code was updated.
            Just got the email and re-installed. I dont see a change in style? Is it just a subtle change?
              See the new ribbon on all my posts on this topic. Previously, the ribbon was displayed diagonally. Check the original screenshot in the first post to see how the old ribbon looked like.
                Fleet, you don't have to apply the new style if you want the old style. It's optional. But to prepare for the upcoming vB 5.3.4 version, you have to at least apply the CSS changes I mentioned in post #32
                  Love it! Thank you!
                    I installed the new topic ribbon. I just dont notice much of a style change. It looks the same. Did i do it right?
                    Edit - Oh wow i see it on your site. The side look. Interesting.
                      As I mentioned in post #34, you don't have to re-install the product XML.
                      Just follow Step 6 to update the CSS. The new ribbon style is Style 3.
                        I made the mod flexible in such a way you could change the ribbon style by just changing the CSS without re-installing the mod. I might add more ribbon styles in the future.
                          But reinstalling the XML updates the CSS right? Thats all i did.
                            No it does not. As I said in my previous post, just follow Step 6 to update the CSS. The new ribbon style is Style 3.
                            There are 3 different ribbon styles to choose from so it cannot automatically update the CSS.
                          #43
                          with:
                          Yea Glenn i did this and it removed the ribbon. lol
                            So you want to keep the original ribbon style? If so, you just have to replace the specified CSS code. I don't know how you did it.
                          #44
                          So uninstalled it and reinstalled and it doesnt show in my first 2 themes. But it does the rest. I dont know man. I did what i was supposed to. CSS additional and replace the first code with the 2nd code. Save and it made the ribbon disappear.
                            I checked your site and I can see the diagonal ribbon in ALL the themes. In TPB Classic theme, the ribbon is gold with gradients and the rest have solid green.
                          • Fleet
                            Yes i simply copied the css from one of the themes and pasted it in the first 2 themes to fix it. I still havnt updated any css though. lol.
                          #45
                          Who wants this ribbon style? This will only work if postbit has solid background color.
