Saiff, I've fixed the issue. You should receive an email containing the download link. Please download the product and install again. Let me know if you find any issues.
thanks, now installed
I do not see the buyer icon verified under my name
No it is not compatible with vBCloud. I will check if it's possible to do this in vBCloud.
As for the Autolinker mod, there are instructions provided in the package. If you need professional help in installing it, I recommend you to purchase the Product Installation Add-On here.
I should have added a fixed font in the CSS. Without it, it would inherit whatever default font is used in the theme and that may cause this issue you encountered.
What do you exactly mean? It works in mobile. It overlaps with the avatar though. But where do you want to place the ribbon? There's no other better place than there. And if you move the avatar, it would not look good.
I checked and the smallest the ribbon it can get without text in it is 60x60 as compared to the default 85x85. But it would still touch the avatar. If you make it smaller, it wouldn't look like a ribbon anymore.
very nice site i am a old site owner use to run vb 3x versions just purchased vbullitin 6 and i want to build a sweet site and hoping for some grea mods...
