I prefer the existing one you have in place for this site, presently.
Topic Starter Ribbon
I installed Glenn's "topic starter" ribbon on my site and it received many positive comments from the users. I used the 3rd Version as i feel it's less intrusive on the avatar pic JMO. Thanks Glenn for all your effort and the help you give me on my site when its needed.
Hey glennrocksvb , just purchased to branded version (link in footer is small and unintrusive, cudos
), but as usual I'm having issues to do with RTL language, here is how it appears when using the first version of the ribbon (the default version from the .txt file):
Could you please help sort this out?
Thanks
Just like before, change left to {vb:stylevar left} and the degrees to 45deg (positive not negative)
Hi glennrocksvb I have just noticed an issue that only occurs in mobile where the ribbon is partially hidden underneath the avatar:
Would appreciate a fix
watershed, add this:
I also adjusted banner width and padding to make it smaller and not cover half of the avatar.Code:.l-small .vmtr-topic-starter > .anchor:before { z-index: 1; padding: 4px 0; width: 108px; }
Just purchased. Dumb question, I'm sure... but where in **** is the ribbon css? I've checked the css_additional but could not find any file with ribbon as the name. Can someone point me to the correct location to add the code?
by kipinnyvery nice site i am a old site owner use to run vb 3x versions just purchased vbullitin 6 and i want to build a sweet site and hoping for some grea mods...Today, 04:03 PM
by daria22My name is Daria. I'm jumping into vBulletin to build a community for my gardening hobby.
I'm hoping to learn more about vBulletin as I recently...Today, 12:22 PM -
My name is Chunk (nickname). Im current graduated from my local college for Web Development. Today I will be exploring vBulletin...07-11-2026, 06:08 AM
