Topic Starter Ribbon
    You just need to copy the CSS code provided in the readme file and paste it in the css_additional.css template
      I just installed and it shows up in the left corner instead of straight horizontal as in this forum. How can I make it like in this forum?
        I'll send the code when I get home.
          Derwin, the readme file contains 3 different styles for the ribbon. Which one are you using? The Style 3 is the one that's used in this forum.
            I'm an idiot. I had style 1 and didn't even notice the rest. Thanks!
              The ribbon is painted over by a frame, if you select a post of the topic starter when using ribbon type 1 or ribbon type 2.
              You can simply fix this by adding z-index: 1; in .vmtr-topic-starter > .anchor:before {} to the css_additional.css.
              without z-index: 1:
              with z-index: 1:
