For computer coding and support kind of forums, it is very helpful and convenient for users to be able to quickly copy the code posted using [PHP], [HTML] and [CODE] BBCode tags with a single click instead of manually highlighting the code and copying it. If you have such forum, this mod is a must!
This plugin is very useful for forums that share code examples and tutorials with their users. It helps users to copy the code easily and accurately without any formatting issues. It also enhances the user experience and makes your forum more convenient and functional.
This mod is installed on this site. You can see the Copy Code button for each code below if you are logged in and have at least one post.
HTML:
PHP:
This is how it looks like on the vB5 Default Style:
CSS Fix (Added on Feb 16, 2022)
There's an issue on Search Modules where if the first line in a post contains a code, the Copy Code button is misplaced. To fix this issue, it's better to just hide the Copy Code button in Search moudle because the code may not be complete since the module only includes an excerpt of the post. To hide the button in Search modules, add this CSS code in css_addtional template:
NOTE: The above custom CSS code to be added in css_additional is no longer needed because it has been added to the mod by default as of v1.2. If you've added it before, you can remove it from css_additional.css template after installing v1.2.
v1.2
Price:
$25 (branding-free)
Enjoy!
- The Copy Code button appears for all code posted using [code], [html] and [php] BBCode tags on topic pages, PMs and activity stream on Homepage and Profile page.
- Clicking the Copy Code button copies the code into the clipboard.
- Can be easily enabled or disabled in the mod settings.
- Can configure which Usergroups can use this feature in the mod settings.
- No existing vB5 template edit required.
- Easy to install/upgrade.
- Allows language translation of the following phrases in Phrase Manager.
- vbmods_copycode: Copy Code
- vbmods_copycode_copied: Copied!
alert('Hello World');
<h1>Hello World</h1>
PHP Code:
echo "Hello World";
/* Hide Copy Code Button in Search Modules - START */
.search-widget .bbcode_container .vbtrCopyCodeBtn {
display: none;
/* Hide Copy Code Button in Search Modules - END */
- Compatible with vB5 and 6 (self-hosted only)
- Not compatible with vBCloud but can be released in the future if there are demands for it.
v1.2
- Added support for Secondary Usergroups.
- Fixed layout issue of Copy Code button on forums with RTL languages.
- Fixed an issue with source code wrapped in [PHP] BBCode tag, wherein the newlines were not preserved.
- Removed red dot in the copied code from clipboard. This was invisible when pasted in some code editors but visible in others and it caused invalid CSS code.
- Initial version
Price:
$25 (branding-free)
Enjoy!
