Main Navigation Menu Dropdown
    Originally posted by rnedelkow View Post
    Hey William, can you share how you got the social icons above the search bar?
    Here's the mod: https://www.vbulletin.org/forum/showthread.php?t=289099
    • rnedelkow
      Thanks for that!
    #62
    How can I disable this addon for tablets only?
      Let me check. Why?
    • 420
      Because my menu (with dropdown) does not properly work on tablets. I wan't to show the same menu to tablet users as my mobile users.
    #63
    thanks glen Purchased
    Receipt number: xxx52569V9576793S
      cant get it to work on VB 5.5.0 ..It shows error at the top..
        Papa Bear, the screenshot is too small it's too hard to see the text. But from what I can see, the text is not an error message but a block of CSS code that's not supposed to show up. That CSS code is not from this Nav Dropdown mod. I need to see the page in order for me to investigate the issue.
          Interesting i went in a saved the templates and it works..no changes just saved it..
            Which template did you save?
          • Papa Bear
            The hook_main_nav_dropdown_menu
            Hmm..this could be a 5.5.0 issue. You didn't have to this saving templates in previous versions. Nothing has changed in this mod.
          • Papa Bear
            Nope..not before..like I said didn’t make any changes just clicked save and reload..
            This might need to be reported to vB so they can look into the issue.
          #67
          Bought, installed and perfect thanks for your work
          A cordial greeting
            #35.1
            05-06-2017, 08:36 PM
            I checked your site and I didn't see that message. Branding-free costs $25.
            hi glen can you tell as when you saying
            Branding-free costs $20 + $25?
              Branding-free itself cost $25. I didn't include this in this mod. It was created before I started adding branding-free license. If you want a branding-free version, please let me know.
                thanks glen @ the time I bought for
                $20 I am willing to donate $5 if you don't mind send me the branding-free version pleas
                thanks
                  As I've mentioned, branding-free is $25 by itself (excluding the base price which is $20 in this case). This is the same price for all the mods with branding-free version regardless of the base price of the mod.
                    now got what you mean so branding free is $45 maybe you should update first post
                    thanks glen
                    first post is bit confused
                      I have a problem I do not work mark channels as read class = "navbar_mark_channels_read" Any solution thanks
                      A cordial greeting
                        I bought your product 3RF57248T57021351 but I have a problem because it does not work to mark channels as read I have configured this hook as explained here https://www.adminammo.com/articles/v...83-how-to-fix- or-add-back-mark-channels-read but I can not get it to work with your product if I disable your product if it works perfectly any help thanks
                        A cordial greeting
                          I will check. But does the link work without the mod?
