Main Navigation Menu Dropdown
    Is it possible to see the installation directions before i purchase this?
      It's almost the same instructions as any other mods. But this particular mod only requires you to upload an XML file in Projects & Hooks > Manage Products in AdminCP. Nothing to upload via FTP or cPanel.
        Sweet i did it. I cant do the cpanel stuff other than background and header. This was easy.
          Are there instructions on how to get the links in the right place on the navbar? Im not a tech guy. lol I struggle to figure this out on my own. I got it installed. But im trying to figure out the navbar maneuvering to get the right sub links in the right drop down menu.
            This mod keeps the existing navbar structure. Whatever main nav and sub nav item structure is preserved. The subnav items will be transformed into a dropdown for the corresponding main nav.
          #50
          How did i get a notification for your post comment? lol
          I cant seem to add to my Nav Bar. It wont save. So i keep exiting out. I cant add a 3rd item to the navbar and save it.
            Hi Glenn,
            I want to make the menu tabs taller in my menu. Could you provide the CSS?
            I want them to be about as tall as the outline:
              I'll check when I get to my computer. I'm on my phone right now.
            #52
            Here you go:
            #channel-tabbar .channel-tabbar-list li a {
                height: 30px;
                line-height: 30px !important;
            .custom-subnav-dropdown {
                top: 30px !important;
            Adjust the values as needed.
              What is the latest version? 1.5?
              For some reason the submenu of "Forums" is not displaying the links (Today's posts, mark Channel read etc) on mobile devices.
                This mod is only for desktop as mentioned in the first post:
                Note: This mod only transforms the main navigation menu for bigger screens (desktop). The navigation menu for smaller screens (mobile) are not changed.
                  Sorry forgot that. But the strange thing is the links like "Today's Posts, Member List" do show (Under the forum tab) on my mobile device when visiting vbmods.rocks/forum
                  But on my forum the Forums menu is not showing the links in the submenu.
                  Could this be because I have added links in the Forums menu?
                    Can't tell without seeing your site.
                  #56
                  I found out it was because of :
                  420 made a workaround by adding a main navigation item with # as the Target URL and then moving the original main nav item as one of its sub nav items. See his post in this thread at: https://vbmods.rocks/forum/vbulletin...pdown#post3726
                  Instead of # i put my forum url in the "Forums" menu.
                    How come only the forums menu shows the links in the submenu? (on this forum on mobile)
                    Why are the links under the menu Premium Mods not being displayed on my Iphone?
                    I would like to have a submenu that shows the links just like the FORUMS menu on small devices.
                    Do you have any idea why this is? And how to achieve this?
                      That's how it is by default in mobile as implemented by vBulletin. Only the current active menu displays the submenu. This is not to say that's not possible to implement. But this is outside the scope of this mod as the mod is for desktop only.
                    #58
                    Glenn,
                    Is there a way to put the mainnav bar into the top menu? If possible I'd like to have the menu fixed in position except when the site builder is accessed:
                    Click image for larger version  Name:	fix bar.jpg Views:	1 Size:	166.0 KB ID:	9293
                      I'll take a look.
                    • NumNum
                      I'm on your site now, love how you pushed the navbar up.
                      When you open the site editor, does it push the navbar down below the site editor navigation?
                    • William
                      Yes, site editor does push the nav bar down.
                    #59
                    I'll take a look.
                    At least I know its possible with only css. I only did css and if I do say myself I did a terrible job. The end result is as seen in the screen shot. The main drop down menus work but mousing over leaves no effect. Somehow I have the menus layered and had to use a zindex to even display correctly. Anyhoot, I really butchered it to get here:
                    • rnedelkow
                      Hey William, can you share how you got the social icons above the search bar?
                    #60
                    William I checked your site and it looks like you figured it out.
