Just noticed that the user status field isn't editable by administrator members which might be used and displayed in the postbit. Is there a way to edit entries?
You can edit the template used in this mod (not recommended to edit existing vB templates) to accomodate the display of country custom field value as flag images.
I figured out a way to display images or CSS icons in the profile field values in postbit. See the Gender field here in my postbit. I am using pure CSS as the Male icon. This solution should enable any type of profile fields that you want to display images or icons instead of plain text. For example, now it's possible to display country flag images for Country custom profile field.
I will post this solution and update this mod when I get a chance.
FYI. I've also added the Country custom profile field in the postbit on this site and it displays the corresponding flag image icon. Please feel free to update your Country in the User Settings if you want. I will release an upgrade to this mod once I know everything is working fine. Thanks!
Hi Glenn,
Is there a way that I can show the profile fields on pc, but not on tablet or phone mode? (And for that matter, I would like that for the standard join date and post count as well)
Hi Glenn,
For the Custom Profile Fields I've added a class to the "hook_profile_fields_postbit" template and added the following in my css_additional.css:
Glenn - this works well. Thank you for making it available! Question... I'm including the location but would like to remove the "Location:" field label and just display the data. Is that possible?
So you want to remove the label for Location and leave it for others?
that's what I was thinking but... sounds like removing Location would also remove Posts, right? So, I guess I wouldn't wan't that. It's not a huge deal... I was thinking it would save a row of real estate. For instance, "Location: Montgomery, AL" wraps to a second row but "Montgomery, AL" doesn't.
AI bots (or any bots for that matter) should still be able to scrape the site and find the hidden content. The content is hidden via CSS which only takes...
