By default, vBulletin 5 only displays the Join Date and Post count in the postbit area (avatar and username section) in the thread view of a topic. There may be other tutorials out there to add custom fields in postbit but some require you to edit the existing postbit template. Editing existing templates is not good for maintenance reasons as you would have to resolve template merge conflicts every time you upgrade. Or some might require you to create a template hook and repeatedly copy/paste template code for adding multiple fields and change instances of profile field variable names. Another maintenance nightmare.
Don't look any further, here's the mod that is simple but rocks! Simply download the zip file, uncompress it and upload the XML in AdminCP > Products & Hooks > Manage Products > [Add/Import Product] and you're good to go. By default, it adds Location and Occupation profile fields. You can configure what profile fields to add in AdminCP > Settings > Options > Custom Profile Fields in Postbit Settings.
As a bonus, the mod also adds "Send PM" link to the postbit to make it easier for users to send a private message to a user while reading a thread. You can also configure that in the Custom Profile Fields in Postbit Settings.
Look at the postbit section on this thread.
Upgrade Instructions:
If you are upgrading this mod from an older version, choose Yes in the "Allow Overwrite" radio button when importing the XML file.
Customizations:
To add the existing envelope icon in the default icon sprite image to the Send PM link, add the below custom CSS in css_additional template in AdminCP or in Sitebuilder > Style > CSS Editor.
For dark colored themes, you can use the light colored envelope icon by changing -16px to 0 in the background value above.
[Feb 21, 2022 Update]: The sprite image containing all the icons used in vB5 has changed since this mod was posted. That's why the image icon will not show up using the sprite_icons_vb_ltr.png image path in the above code. To find where the new location of the sprite image file is, right-click any of the icons on your forum and then choose Inspect. Observe the background used and locate the image path inside the "url(" and ")". Copy that path and use it to replace the image path in the above code.
NOTE: With recent updates from vBulletin 5, you can now show profile fields on postbit without a third-party plugin. This is done by setting "Show on Post" to Yes when creating/updating a profile field in the User Profile Field Manager and it will show on postbit.
But if you want to show icons instead of text, then you still need a plugin to do that. I just released new mods for displaying Gender icons and Country Flag icons on postbit.
Customizations:
.send-pm-in-postbit:before {
content: '';
width: 15px;
height: 14px;
position: relative;
bottom: -1px;
background: transparent url('images/css/sprite_icons_vb_ltr.png') no-repeat scroll -16px -176px;
display: inline-block;
margin-right: 3px;
- Added rel="nofollow" to Send PM link to prevent search engines to follow the link and get Access denied error.
- Initial version.
