Thanks Glenn - just bought you a couple "PayPal" beers!
Add Custom Profile Fields in Postbit
Hey glennrocksvb thanks for yet another great mod!
I seem to be having an issue with the message icon not showing. I have an RTL forum so tried to change in the css to the rtl version of the .png file (Also exists on server) but that didn't work either.
You can check it live here for example: https://hakafe.net/node/35
Thanks
And one final issue to report, this seems to mess up the alignment on the mobile style, even if I leave just one field. When removing all fields (with the mod still on), this problem goes away on mobile. Anyway to disable this on mobile styles?
By default, the profile fields are styled with display:inline-block which means they are displayed next to each other in the same line until it wraps to the next line. If you want each field to display in its own line, then you need to set it to display:block
Code:.l-small .b-userinfo__additional-info { display: block; }
It looks like starting vB 5.4.4 or 5.4.3, they changed the old PNG sprites file and removed the envelope icon. The preferred and new way of using icons is via the SVG sprites. This is the SVG sprites used on your forum: https://hakafe.net/sprite.php?stylei...&ts=1542587853. So try using this code instead (changes are in red):Originally posted by watershed View PostI seem to be having an issue with the message icon not showing. I have an RTL forum so tried to change in the css to the rtl version of the .png file (Also exists on server) but that didn't work either.
Code:.send-pm-in-postbit:before { content: ''; width: 15px; height: 14px; position: relative; bottom: -1px; [COLOR=#B22222]background: transparent url(https://hakafe.net/sprite.php?styleid=36&td=rtl&sprite=sprite_icons_general.svg&ts=1542587853) no-repeat 0 -176px;[/COLOR] display: inline-block; [COLOR=#B22222]margin-{vb:stylevar right}: 3px;[/COLOR] }
Did you specify it as field2,field4 instead of just 2,4?
Make sure those fields in the User Profile Field Manager in AdminCP have the "Private Field" option set to No. And also if those fields are empty in the User Setttings for a user, then those fields are not displayed in postbit.
How about if they are empty only for some users, not all? Still won't appear?Originally posted by glennrocksvb View PostMake sure those fields in the User Profile Field Manager in AdminCP have the "Private Field" option set to No. And also if those fields are empty in the User Setttings for a user, then those fields are not displayed in postbit.
The mod works here. I'd have to check your setup to see what's wrong.
Reply to TikTok BBCodeby glennrocksvb
Works for me in vB 6.2.2.
How does it look like on your end. Do you not see a video at all? Can you post a screenshot?...Yesterday, 09:36 PM -
My name is Chunk (nickname). Im current graduated from my local college for Web Development. Today I will be exploring vBulletin...07-11-2026, 06:08 AM
how to add the country flag png to it?
