Embedded Audio Attachments Player
    Hi,
    Just bought your installation add-on. Email sent.
    Regards
      Hi,
      Is it possible to disable the 'Save the MP3 URL as' or 'send the MP3 link by email' by using the right click (under FireFox by example) ?
      Right now, the audio files are inside a directory above the web ...
      Best Regards
        No. You can't totally prevent the audio file (or video or any other web resource for that matter) from being downloaded by the user. You can make it harder but it would require custom coding.
        See this same discussion in Stack Overflow
        How can I disable "Save Video As..." from a browser's right-click menu to prevent clients from downloading a video? Are there more complete solutions that prevent the client from accessing a file ...
          Hi,
          Does the mod work under 5.6.6 / PHP 8?
          Regards
            I will check.
          Originally posted by lange View Post
          Hi,
          Regards
          lange I tested it and this mod works in vB 5.6.6. and PHP 8. This mod just uses pure JavaScript to convert audio file attachments into an audio player. It doesn't involve any PHP coding that requires PHP version compatibility. This is the same case with the Video Player mod.
          • lange
            Thank you, I will install this mod then. I will also install the Video Play mod under 5.6.6.
