Embedded Video Attachments Player
    Paid Mod Embedded Video Attachments Player
    This is a vB5 mod that transforms existing video file attachments into an HTML5 Video player.
    Click image for larger version  Name:	video-player.png Views:	1 Size:	206.5 KB ID:	12140
    Click image for larger version  Name:	video-player-mobile.png Views:	1 Size:	78.3 KB ID:	12145
    Notes before purchasing this mod:
    • This is compatible with self-hosted version only. Though it's technically possible to implement a vBCloud version of this mod, the vBCloud server provided by vBulletin may not be powerful enough to handle large video uploads. If you are on vBCloud and interested in this mod, ask vBulletin support first if they allow this set up (see next notes).
    • Make sure your server has enough storage for uploaded videos.
    • Make sure your server has enough bandwidth for high data traffic due to large videos.
    • Make sure you can set Attachment Storage type to File System instead of Database.
    • Make sure your server is powerful enough to handle large video uploads.
    • Make sure that Max Post Size and PHP Maximum Upload Size values in PHP configuration are equal or greater than the Max File-size you set in the MP4 extension. Ask your host if you need help changing the PHP configuration.
    • Once you purchased this mod and downloaded it, you can no longer ask for a refund.
    NOTE: Since vB 5.6.8, embedded videos have been natively supported (see this for more details). So this mod is no longer needed.
    Watch the demo video screencast from YouTube below.
    Absolutely love it, exactly what I have been looking for! What are the file limitations?
      You will need to add a new file extension mp4 in the Attachments Type Manager in AdminCP and set the Max file size option. You will also have to make sure that your server has large storage capacity and it can handle large file uploads by setting PHP Max Post Size and PHP Maximum Upload Size to values that are equal to (or greater than) the max file size you set. It is also highly recommended that you move your attachments from database to file system to avoid having very large database.
        Perfect, my settings are already set for this then! Thank you Glenn! I'm super excited that this will work on all the already posted video files without any kind of major time investment! I think this one has been a long time coming and anyone running a vb site will see great value in having this on board for their users.
          We need a cloud version
            Yes, it is also possible in vBCloud if they allow setting file attachment storage from database to file system. You may want to ask vBulletin staff first.
              Also ask them what the maximum values allowed for Max Post Size and PHP Maximum Upload Size
                Asking that question will have to wait. I have to many pressing issues going on over there right now that are not getting resolved efficiently
                When you login to AdminCP, what values do you see for Max Post Size and PHP Maximum Upload Size in the AdminCP homepage.
              PHP Max Post Size 20.00 MB
              PHP Maximum Upload Size 15.00 MB
                Ok. That's not enough for a single video upload. I have a 28-sec video on my phone and it is 78MB in size.
                Ok thanks for looking into it
              keyla31 and to all those who are interested, this mod is now available!
              • keyla31
                installed and working great - absolutely perfect
              I got reports that videos don't load and play on iOS devices. This was reported by X79 and I confirmed the issue with the help of keyla31 that even without this mod, the video still does not play when loading the video URL directly on iPad/iPhone. This confirms that this is a server issue and not a mod issue.
              Apparently, this is a widely known issue for iOS. I researched for this issue and found this.
              We have an MP4 video on our site; it plays fine in IE9+, Firefox, Chrome, and Chrome on mac. However, on Safari, the video doesn't play at all - it does trigger a "stalled" event and then nothing l...
              The top answer in that stackoverflow post says:
              Safari requires webserver to support "Range" request header in order to play your media content.
              https://developer.apple.com/library/...TP40006514-SW6
              For a legit "Range" request response, your webserve need to return status code "206".
              If you follow the developer.apple.com link posted, you will see this:
              Click image for larger version  Name:	image.png Views:	1 Size:	49.1 KB ID:	12432
              So the solution to this iOS issue is to configure the server to accept byte-range requests. I googled on how to do this and found this link for Apache server:
              https://serverfault.com/questions/39...-range-request
              You may need to contact your hosts to get assistance on how to configure the server to accept byte-range requests. This is outside the scope of this mod.
              Please let me know if you have any questions.
                If you've confirmed with your host that the server is configured to accept byte-range request but the video is still not playing on iOS, then it might be a vBulletin issue. It will help if you can open a bug in the vBulletin bug tracker system. But I'm looking for a solution if this is the case.
                  I reported this issue in the vB bug tracker.
                  Please vote for it!
                    I also posted in vbulletin.com about this issue to get more attention.
                    https://www.vbulletin.com/forum/foru...on-ios-devices
                    This is obviously outside the scope of this mod. But I will watch that bug report closely and will post an update here once vBulletin makes progress on fixing it.
                      Thanks keyla31 for posting the findings of your server admin in regards to the iOS issue to the vB ticket. His findings confirm it is a vBulletin issue and not a server issue (and not an issue on the mod too).
                      "I ran it as requested:"
                      # curl -i -X HEAD --header "Range: bytes=50-100" https://www.domain.com/filedata/fetch?id=1186145
                      HTTP/1.1 200 OK
                      Date: Mon, 27 Aug 2018 22:45:58 GMT
                      Server: Apache/2.2.15 (CentOS)
                      X-Powered-By: PHP/7.1.20
                      Set-Cookie: bbsessionhash=xxxxxxxxxxxxx; path=/; secure; HttpOnly
                      ETag: "312951"
                      Accept-Ranges: bytes
                      Content-transfer-encoding: binary
                      Content-Length: 53053836
                      Content-disposition: attachment; filename="My Movie3 (2).mp4"
                      Cache-control: max-age=31536000, private
                      Expires: Tue, 27 Aug 2019 22:45:59 GMT
                      Pragma:
                      Last-Modified: Mon, 27 Aug 2018 21:03:01 GMT
                      Connection: keep-alive, close
                      Content-Type: unknown/unknown
                      curl: (18) transfer closed with 53053836 bytes remaining to read
                      "I then ran it using a direct .mp4:"
                      # curl -i -X HEAD --header "Range: bytes=50-100" https://www.domain.com/blog/wp-content/uploads/2017/07/sample_FB-21.mp4
                      HTTP/1.1 206 Partial Content
                      Date: Mon, 27 Aug 2018 22:47:47 GMT
                      Last-Modified: Fri, 28 Jul 2017 14:23:56 GMT
                      ETag: "70e1f7c-3d201cd-555616e673700"
                      Content-Length: 51
                      Content-Range: bytes 50-100/64094669
                      Content-Type: video/mp4
                      curl: (18) transfer closed with 51 bytes remaining to read
                      "It works with direct .mp4, but not through the script. This tells me everything is setup on the server correctly."
                      For more details see this ticket: https://tracker.vbulletin.com/vbulle...3#comment_5919
                      • keyla31
                        Now let's sit back and hope Vbulletin addresses it.
                      Update: vBulletin has updated the bug ticket I created for them and confirmed this is a vBulletin issue. They have assigned a vBulletin developer to fix this issue and have assigned a Fix Version which means this will be fixed in the upcoming vBulletin version. Not sure which version though. But it's good to know that this issue is being addressed sooner than I expected.
                      Click the link below to see more details of the ticket.
                      I've also attached a screenshot of the ticket below for quick reference.
                      • keyla31
                        This is great, at least we know its in progress
