This is a vB5 mod that transforms existing audio file attachments into an HTML5 Audio player.
Notes before purchasing this mod:
NOTE: Since vB 5.6.8, embedded videos have been natively supported (see this for more details). So this mod is no longer needed.
Watch the demo video screencast from YouTube below.
- This is compatible with self-hosted version only and not with vBCloud.
- There is a known issue on vBulletin where audio (as well as videos) do not play on iOS devices on vB 5.4.4 and below. There is a bug ticket for this at https://tracker.vbulletin.com/vbulle...sues/VBV-18743. vBulletin has fixed this issue and the fix was released in vB 5.4.5 version.
- Make sure your server has enough storage for uploaded audio files.
- Make sure your server has enough bandwidth for high data traffic due to large audio.
- Make sure you can set Attachment Storage type to File System instead of Database. (Optional but recommended)
- Make sure your server is powerful enough to handle large audio uploads.
- Make sure that Max Post Size and PHP Maximum Upload Size values in PHP configuration are equal or greater than the Max File-size you set in the MP3 extension. Ask your host if you need help changing the PHP configuration.
- Once you purchased this mod and downloaded it, you can no longer ask for a refund.
