yamijhon, for vB3 or vB4, remove class="h-align-center" and replace it with style="text-align: center;"
Simple Rotating Banner Script
Great script thanks and I've moved the search box into the navbar but after many, many hours I just can't get this into the Header bar (where the search box was) to the right of our logo.
Seems using hooks is the right way to go, but the only hooks in the header area seem to be above the logo, below the logo but not in the spare right of the logo.
Anyone please have some clues how to get a rotating banner into that space?
Ok prob a basic question
Using Glenn's rotating banner how can I resize all the pictures to be the same? These pictures have internet links
example
What would be added to the (SRC) url link in the code?
Unfortunately, I can't see your example code above because I don't have permission to do that.
You could try adding styling after the rotateBannerImg id like this:
This code would make all images resize or stretch to 500px.Code:style="height: 500px; width: 500px;"
EDIT: Adding this to your CSS template would also probably work:
Code:#rotateBannerImg { width:500px; height:500px; }
Thank you for the reply. I ended up changing each photo to this format with Medium. That ended up making them all pretty much equal in size.
'https://www.vintagefordforum.com/filedata/fetch?photoid=244541&type=medium'
