Simple Rotating Banner Script
    Is there anything that I can add to just that banner module to prevent right click. I realize there are work arounds but I would still want to add it
    thanks
      thsnkd
      I don't personally recommend this but since you asked...
      window.addEventListener('load', function() {
          document.addEventListener('contextmenu', function(e) {
              if ($(e.target).closest('#widget_XXXXX').length > 0) {
                  alert('Sorry, right click is disabled in this module.');
                  e.preventDefault();
                  return false;
              return true;
      Change XXXXX to the corresponding widget id of the target module.
        So I put this in CSS and nothing happened.
        I got this ID from inspect
        id= widget_336.
        I put 336 into your code
          It's not CSS. It's Javascript. So put it inside <script> </script> tags.
        Sorry but i'm not sure. So the code goes between the script tags like I did here? Then it gets pasted to the module?
        <script>
              if ($(e.target).closest('#widget_336').length > 0) {
                 e.preventDefault();
                 return false;
              return true;
        </script>
        Last edited by glennrocksvb; 11-12-2018, 06:14 PM. Reason: Fixed code formatting using [code] tags
        Okay that worked.. Thanks Glenn
        More coffee coming sir
        Hi Glenn
        Thanks for the code, its working great!
          question about this mod...
          only works with several images but just one link?
          or u can put, may be, 10 images with 10 links?
            Yep 10 images, 10 links, you get a link per image
              thanks Barkyj
                You can put as many images as you want. As Barkyj said, you get a link per image. Just update the bannerImages Javascript variable found in post #1 with the appropriate set of image src and link. Follow the format of the sample provided and take note of the code comments in // or /* */ characters.
                  tnx 2 u also dude...
                  but, another question, the size of each image is auto or i need to put some extra code?
                    I sized my images before I uploaded them, 1160x200 is what I used, unsure what happens if the images are too big though.
                      It should automatically scale down to whatever available space.
                        ok, i'm stuck with this...
                        i tried to put the code in header and footer, none of those works, am i doing something wrong?
                        <div class="h-align-center">
                            <!-- Insert default image and link here -->
                            <a id="rotateBannerLink" href="http://www.directemar.cl" target="_blank"><img id="rotateBannerImg" src="http://www.denunciasbuceo.cl/foro/banners/direct.jpg" alt="" /></a>
                        </div>
                        <script>
                        (function() {
                            // list down all possible images and links here
                            var bannerImages = [
                                        link: 'http://www.dt.gob.cl',
                                        src: 'http://www.denunciasbuceo.cl/foro/banners/dt.jpg'
                                        link: 'http://mma.gob.cl',
                                        src: 'http://www.denunciasbuceo.cl/foro/banners/mma.jpg'
                                        link: 'http://www.sernapesca.cl',
                                        src: 'http://www.denunciasbuceo.cl/foro/banners/sern.jpg'
                                        link: 'http://www.ssffaa.cl',
                                        src: 'http://www.denunciasbuceo.cl/foro/banners/subs ffaa.jpg'
                                    /* no trailing comma here at the last item */
                                link = document.getElementById('rotateBannerLink'),
                                image = document.getElementById('rotateBannerImg');
                            // function to get a random banner from the list of banners
                            function rotateBanner() {
                                var index = Math.floor(Math.random() * bannerImages.length);
                                image.src = bannerImages[index].src;
                                link.href = bannerImages[index].link;
                            if (link && image) {
                                // rotate the banner every 3 seconds
                                window.setInterval(rotateBanner, 3000); //1000 (msec) = 1 sec (adjust as needed)
                            } else {
                                console.log('Error: Link and/or image does not exists. Make sure the <a> and <img> IDs are correct.');
                        </script>
                        edit: now is working... but i can't put in center, it appears to left side of forum, some help please??
                          Can you post or PM a link to your site? The image should be centered because of the h-align-center class in the div container. There might be other CSS that's overriding the slideshow CSS.
