Removed, I don't want to confuse people with a different code.
Tweet BBCode
Fixed and updated code in the first post.
Here's a sample tweet URL with querystring parameters:
https://twitter.com/vbmodsthatrock/status/1489663748491157511?s=20&t=3i-9zc-TquBRaRNe6r2otg
My Amazon Affiliate Link β
I checked and I confirmed that Firefox is not showing the embedded tweet. After investigating, Firefox is blocking Social Media trackers (which include Twitter) by default using the default "Strict" mode for Enhanced Tracking Protection option.
If you click the shield icon next to the SSL lock icon in the Firefox address bar, you will see "Social Media Trackers" is blocked. If you expand it, you will see the Twitter API URL. If you want to change the security settings, click "Manage protection settings" and switch from "Strict" to "Standard" and then click "Reload All Tabs" and then check that the embedded tweet should now be displayed.
Hello Glenn. I am writing this message because none of the icons that I put in the bbcode work right. With the tiktok one, in the preview, it looks correct. However, when I go to post it, I only get the actual tiktok line. I was wondering what I am doing wrong.Originally posted by glennrocksvb View PostOne way to integrate social media with forums is to embed tweets from Twitter into forum posts.
Go to AdminCP > Custom BB Codes > Add New BB Code and enter the following information:
Title: Tweet
BB Code Tag Name: tweet
Replacement: (Updated code as of 02/26/22 to fix issue for Tweet URL with querystring parameters)
Example: [tweet]TweetUrlOrTweetIdHere[/tweet]Code:<div data-tweet-param="{param}"></div><script>(function(){function k(a,c){var d=Element.prototype;return(d.matches||d.webkitMatchesSelector||d.mozMatchesSelector||d.msMatchesSelector||function(a){return-1!==[].indexOf.call(document.querySelectorAll(a),this)}).call(a,c)}function g(a,c){return a?k(a,c)?a:"HTML"===a.tagName?null:g(a.parentNode,c):null}var b,u=`{param}`.replace(/<br\s*[\/]?>/gi, '').replace(/\r|\n/g,'').replace(new RegExp(unescape('%26amp;'), 'g'),unescape('%26')),a,e=document.getElementsByTagName("script"),e=e[e.length-1],f;if(/^http[s]*:\/\//.test(u)){a=document.createElement("a");a.href=u;b=a.pathname.substring(a.pathname.lastIndexOf("/")+1)}f=e.parentNode.querySelector('[data-tweet-param*="'+u+'"]:empty');(a=g(f,".js-post"))?a=a.getAttribute("data-node-id"):(a=g(f,".js-post-sm"),a=a?a.getAttribute("data-nodeid"):Math.floor(Math.random()*10000));a="t_"+(a||"")+"_"+b;window[a]=function(a){f.innerHTML=a.html;a=f.getElementsByTagName("script");for(var c,d=document.getElementsByTagName("head")[0],b=0;b<a.length;b++)a[b].src?(c=document.createElement("script"),c.src=a[b].src,d.appendChild(c)):eval(a[b].textContent)};var h=document.createElement("script");h.src="https://api.twitter.com/1/statuses/oembed.json?id="+b+decodeURIComponent("%26")+"callback="+a;e.parentNode.appendChild(h)})();</script>
Other Options: Select Yes to all starting from "Remove Tag If Empty" option (for Button Image option, you could specify image path. If specified, a new button for this BB Code will appear in the editor)
This tweet:
[tweet]https://twitter.com/noypiscripter/status/758114543033647104[/tweet]
or just using the Twitter Post ID
[tweet]758114543033647104[/tweet]
will be rendered as:
To get the Tweet URL, go to a tweet on Twitter, click on the 3 dots icon below the tweet, choose "Copy link to Tweet" and then copy the URL.
Other sample:
None of them work correctly. How can I fix this?
The Twiiter JS API is returning 404 Not Found error. They might have changed the API location since they changed to X or they did deprecated the old Twitter API.
I'll research for the new X API and update the BBCode.
Seems like the Twitter BBCode is now working. I didn't have to make any change. Maybe there was just a glitch on Twitter side before.Originally posted by lottidah View PostTest Tweet.
Reply to TikTok BBCodeby glennrocksvbFor that specific TikTok video, the BBCode doesn't seem to be the issue. I also tried using the official embed HTML code provided by TikTok in a forum...Today, 03:57 PM
Reply to TikTok BBCodeby flohse
The video loads, but does not play. Clicking on the play control has no effect.
β
I have found out that it varies from video...Today, 11:14 AM -
Works for me in vB 6.2.2.
β
How does it look like on your end. Do you not see a video at all? Can you post a screenshot?...Yesterday, 09:36 PM
