Does this still work?
Tweet BBCode
The tweets in the first post are still working. The reason it doesn't work on your post is because when you pasted the tweet post id, it was formatted with color, font family and font size and left alignment. It should be pasted as plain text without any formatting.
My Amazon Affiliate Link β
Oh, I should have realized. That's a relief. Thank you.Originally posted by glennrocksvb View PostThe tweets in the first post are still working. The reason it doesn't work on your post is because when you pasted the tweet post id, it was formatted with color, font family and font size and left alignment. It should be pasted as plain text without any formatting.
This made me think to fix this and automatically remove the formatting. I'll post the code when I figured it out.Originally posted by glennrocksvb View PostThe reason it doesn't work on your post is because when you pasted the tweet post id, it was formatted with color, font family and font size and left alignment. It should be pasted as plain text without any formatting.
Hey Glenn
I've had this on my site for sometime and always thought you could only do the ID to render the tweet. I came here tonight and saw the original post said you can actually use the whole link as well, so I tried it.
Using the ID works perfect on my board, but using the whole URL produces Twitter"> in the post after submitting.
I'm making sure that the URL doesn't have the link format and it's just text.
I'm sure it's something I'm doing. Any advice?
I'm actually seeing that same Javascript error on this page 3 of this thread at post #31. The OP posted a tweet but she pasted the tweet ID as formatted text causing the tweet bbcode to fail parsing the tweet id. This causes the embedded tweet to display blank. In your case Fleiding it still displays the tweet text but without the CSS layout. The solution is when you copy the tweet URL or ID from twitter.com and paste it inside the [tweet] bbcode, don't use the keyboard shortcut for pasting (CTRL+V or equivalent) but instead right-click and choose the 'Paste as plain text' option to remove any copied formatting. Try this if this solution will also work for you Fleiding.Last edited by glennrocksvb; 09-17-2018, 09:28 AM.
I have a test installation with vB 5.4.5 and the tweet BB Code is still working.Originally posted by ABDURHMAN View PostThe code does not work on the new version vb545
Did you follow the steps on how to create the BBCode in the first post and the sample format to use on how to post a tweet inside the BBCode?
by ausfishJust trying to see this post
https://vbmods.rocks/forum/questions...indexing-missi...Yesterday, 10:57 PM -
Reply to TikTok BBCodeby flohseThis may be the case. I was just surprised because that hadn't been the case before, and the video had played normally. So there is nothing we can do....Yesterday, 08:57 PM
Reply to TikTok BBCodeby glennrocksvbFor that specific TikTok video, the BBCode doesn't seem to be the issue. I also tried using the official embed HTML code provided by TikTok in a forum...Yesterday, 03:57 PM
