Tweet BBCode
    Update: It only works by tagging [Tweet]ID[/Tweet] on my forum. Otherwise it just posts a plain link.
    Over here it embeds automatically.
      Did you mean it doesn't work when you use the full Tweet URL inside the [tweet] tags? It works here.
      My Amazon Affiliate Link ​
        It works with the tags, but it does not work when I simply past the Twitter Link.
        Xenforo has it automatically embed.
          vB doesn't have auto-embed without using BBCode. And I don't have any mod for it yet.
            Ah, I see. In the meantime, would the codes that show our location/country at the side below the avatar be available?
              pakistaniandproud
              Display Country flag icons on postbit using this mod. It shows the country flag of the user based on the value of the Country Profile Field. This plugin is very useful for forums that have users from different countries and regions. It adds a nice visual touch to the posts and helps users to identify the location of other
                This one is working as charm, on vb6.0.4 Thank You so much !
                  Thanks for confirming this mod works in latest vB6 version.
                On vb 6.0.6 WORKS ... nice GLENN!
                  Thanks for confirming it works in the latest vB 6.0.6 version.
                I cant seem to get the code right to embed tweets/videos into the forum for X platform formerly known as Twitter This is the code below I added to my bbcode but it dont work,I dont suppose you would know exactly what i need to do to fix this I uesed this below Step 1: Access BBCode Manager
                1. Log in to your vBulletin Admin Control Panel.
                2. Navigate to BB Code Manager under the Custom BB Codes section.
                Step 2: Add New BBCode
                1. Click on Add New BB Code.
                2. Fill in the following details:
                  • Title: X Post
                  • BB Code Tag: xpost
                  • Replacement:HTML <div class="x-post"> <blockquote class="twitter-tweet"> <a href="https://x.com/$1/status/$2"></a> </blockquote> <script async src="https://platform.twitter.com/widgets.js" charset="utf-8"></script> </div>
                  • Example:[xpost]elonmusk|1234567890[/xpost]
                  • Description: Embeds a post from X (formerly Twitter)
                ​I am using Vbulletin 4.2.1 any help would be great
                Remove Tag If Empty
                Yes
                Disable BB Code Within This BB Code
                Yes
                Disable Smilies Within This BB Code
                Yes
                Disable Word Wrapping Within This BB Code
                Yes
                Disable Automatic Link Parsing Within This BB Code Yes
                  I don't think you can use $1 and $2
                  You use {option} and {param} like this:
                  https://x.com/{option}/status/{param}
                  And the BBCode would be:
                  [xpost=elonmusk]1234567890[/xpost]
                    I'm hearing issues where the Tweets don't show up in the Safari (iPhone and iPad) browser, but they do show up on Chrome. Have you of this happening or is there a fix we can implement to have it work on Safari?
                      I don't have Safari to test and replicate the issue. Reload the page with the Twitter/X embed while the Javascript Console is open. Please check for related Javascript errors and post a screenshot here
                    FYI, I have updated the BBCode in the first post to fix missing tweet when there were multiple posts with the same tweet, only the last tweet would show.
