How do I prevent this
Name:	Screen Shot 2024-03-24 at 10.22.00 AM.png
    body_background variable is not using an image. It contains:
Name:	Screen Shot 2024-03-24 at 10.30.32 AM.png
    The background image I'm using is saved at core/images/misc/water.jpg
    I'm using the following additional_css.css code:
    body {
        background: url("core/images/misc/water.jpg") no-repeat center fixed;
        background-size: cover;
    I desire that only the page background shows this image, and no other 'windows' show it.​
      Thank you. That takes care of the issue very nicely.
        Well, here's another 'window' that shows the body background image that shouldn't (that I don't want):
Name:	Screen Shot 2024-03-25 at 9.40.50 AM.png
          Good catch! I'll check.
            Posted the solution in the other topic:
              Saw that. Applied the fix and problem solved. THANK YOU!
