Hello
How are you
After promotion version 6.0.4
I updated the counters and during the update the search index was rebuilt
This problem appears to me
How are you
SELECT 'وقمت' UNION ALL SELECT 'النماذج' UNION ALL SELECT 'الإداريين' UNION ALL SELECT 'هداه' UNION ALL SELECT 'عقبة' UNION ALL SELECT 'مشروعات') AS `inputwords` INNER JOIN `vb_words` AS `words` ON `words`.`word` = `inputwords`.`word`; MySQL Error : Thread stack overrun: 279024 bytes used of a 299008 byte stack, and 20000 bytes needed. Use 'mysqld --thread_stack=#' to specify a bigger stack. Error Number : 1436 Request Date : Monday, April 15th 2024 @ 07:58:06 AM Error Date : Monday, April 15th 2024 @ 07:58:06 AM Script : https://www.ao/vb/admincp/misc.php?do=doindextypes Referrer : https://www.ao/vb/admincp/misc.php?do=chooser& IP Address : UseUsername Mahmoud Classname : vB_Database_MySQLi MySQL Version : 8.0.35-cll-lve Stack Trace: #0 vB_Database->getErrorData() called in phar://[path]/vb/vb.phar/database.php on line 1 #1 vB_Database->halt() called in phar://[path]/vb/vb.phar/database/mysqli.php on line 1 #2 vB_Database_MySQLi->execute_query() called in phar://[path]/vb/vb.phar/database.php on line 1 #3 vB_Database->query_read() called in phar://[path]/vb/vb.phar/db/result.php on line 2 #4 vB_dB_Result->rewind() called in phar://[path]/vb/vb.phar/db/result.php on line 2 #5 vB_dB_Result->__construct() called in [path]/packages/vbdbsearch/db/mysql/querydefs.php on line 1343 #6 vBDBSearch_dB_MYSQL_QueryDefs->fetchExistingWords() called in phar://[path]/vb/vb.phar/db/query/method.php on line 2 #7 vB_dB_Query_Method->execSQL() called in phar://[path]/vb/vb.phar/db/assertor.php on line 2 #8 vB_dB_Assertor->assertQuery() called in phar://[path]/vb/vb.phar/db/assertor.php on line 2 #9 vB_dB_Assertor->getRows() called in [path]/packages/vbdbsearch/core.php on line 740 #10 vBDBSearch_Core->addWords() called in [path]/packages/vbdbsearch/core.php on line 246 #11 vBDBSearch_Core->indexTextBatch() called in phar://[path]/vb/vb.phar/search/core.php on line 1 #12 vB_Search_Core->indexBatch() called in phar://[path]/vb/vb.phar/library/search.php on line 1 #13 vB_Library_Search->doIndexNodeList() called in phar://[path]/vb/vb.phar/library/search.php on line 1 #14 vB_Library_Search->indexRangeFromNode() called in [path]/admincp/misc.php on line 221 #15 require_once([path]/admincp/misc.php) called in /home/absbaco/public_html/vb/includes/api/interface/collapsed.php on line 149 #16 Api_Interface_Collapsed->relay() called in /home/absbaco/public_html/vb/includes/vb5/frontend/controller/relay.php on line 33 #17 vB5_Frontend_Controller_Relay->admincp() called in /home/absbaco/public_html/vb/index.php on line 65
