Uncheck Remote File Checkbox in CKEditor Image Dialog By Default
    Free Mod Uncheck Remote File Checkbox in CKEditor Image Dialog By Default
    When clicking the Image button in the CKEditor toolbar, it shows the 'Retrieve remote file and reference locally' checkbox checked by default in the Image dialog.
    Click image for larger version  Name:	image.png Views:	0 Size:	101.1 KB ID:	28094
    If you want this checkbox to be unchecked by default, then this mod is for you!
    By keeping the checkbox unchecked by default, it encourages users to insert images from an external URL and not upload the file to your server.
    This mod uses Template Hook system to uncheck the checkbox. It works on both vB5 and vB6 including vBCloud.
    Please click the Image icon in the CKEditor toolbar on this site.
    NOTE:
    For self-hosted vB 5/6, please ignore steps 1 and 2 in the readme file. It was a mistake. There's no "upload" folder to upload to the server.
    This is a free mod. The source code for this mod may look short and simple but figuring out the solution was not simple and it required creativity and expert knowledge of vB5/6 Javascript codebase and Javascript in general. Please consider donating so we can continue providing free mods for you. Thank you!
    Download the corresponding file from the attached files below.
    Uncheck 'Retrieve remote file and reference locally' By Default (Self-hosted).zip
    Uncheck 'Retrieve remote file and reference locally' By Default (vBCloud).zip
    thx Man
      Glad to be helpful MahmoudE9!
      Star Wars Salute GIF
        glennrocksvb
        Hello
        How are you ?
        After upgrading to version 6.0.2, the hack no longer works?
        Is there a solution?
        Thank you​​
          Thanks for reporting. I'll look into it.
            Thank you, my friend, for the quick response
              I installed this mod in the latest version vB 6.0.3 and it is still working.
                thank you my friend
                I deleted the product from the forum and uploaded it again and now it works
                  I was desperately searching for a solution for this particular detail, and yours worked like a charm (VB 6.0.5)
                  Thanks you so much for this!
                    It was tested on version 6.0.6 and it works successfully
                      Awesome! Thanks for letting us know.
                    Glenn,
                    I downloaded the file for self hosted and there is no Upload folder in the zip file.
                      Sorry, there's no 'upload' folder to upload to the server. It was a mistake in the readme file. Just install the product XML file in AdminCP.
                        John Waggoner, thanks for letting us know. I added a note in the first post to ignore the upload steps.
                          Glenn, it does work. I guess I didn't refresh the page enough to see it in action. Thanks.
                            Hello
                            Thank you for your efforts
                            It doesn't work on my site​
                            The version used : vb575
                            php 8.1
                            https://www.gamezers.com
