Originally posted by lzvid
View Post
Channel Viewer Counter
Yes, it works in vB 5.7.4 and PHP 8+
As far as I can tell, yes. But if I become aware that it's not working, I do my best to provide a fix.
Hello, I hope to develop the add-on and make it more accurate in calculating the number of people in the departments.
Also, I hope the names of the members will appear in the sections and topics, as in the old versionshttps://www.gamezers.com
This mod is just fetching the number of records in the session table that's already being recorded by vBulletin. If you think it's not accurate then the session handling by vBulletin itself has to be updated and not the mod. User info could be added but that's about it.
First of all, thanks for your purchase. You've earned your Buyer badge.Originally posted by mbrmbr View PostThanks, any way to remove the italics?
To remove the italics, add this custom CSS in css_additional.css template:
Code:.forum-list-container .forum-item .cell-forum .viewer, .sg-table .viewer, .blogChannel-table .viewer { font-style: normal !important; }
Did you just upgrade to vB 6.1.0? What was your previous version when the mod was working?
I checked vB 6.1.0 and I can confirm the mod is not working. It seems that vBulletin made the changes in the session table which the mod is using. I'll keep looking for a solution. Stay tuned.
Wait, I looked into it further and it looks like the mod is actually working. There's just a display issue where the viewer count is displayed in the next line. This is mentioned in the first post and the CSS solution is posted there.
Blackhorse, could you describe in more detail of what's not working on your end?
It stopped working with me since upgrading to vb6.0Originally posted by glennrocksvb View PostDid you just upgrade to vB 6.1.0? What was your previous version when the mod was working?
I just tried to concentrate this tiime on making it work with vb6.1
but completely not working for me
I have implmented the css you have provided to correct being: "displayed in the next line." but hadn't fix it.
after uploading the mod, and the xml file nothing happens, the count views beside forums are not there as usual as it wascould you describe in more detail of what's not working on your end?
Glad you figured it out. That's a vB bug where it doesn't automatically cache mod templates when installing a mod and cache templates as files setting is enabled. I actually have that as part of mod installation instructions for newer mods I release.
Hey Glenn. I recently bought the Channel Viewer mod for my vbulletin forums, version 5.7.5. However, I don't see it working at all. I followed your instructions. I am not sure what I did wrong. Can you help me out?
Hello Glen. I wanted to tell you that I bought the Channel view mod. I did everything that you told me to. But, it's not working for my three forums.Originally posted by glennrocksvb View PostShowing the number of viewers next to forum channels is a basic forum functionality but this is missing in vBulletin 5 and 6 by default. Worry no more as you can have this functionality in your vBulletin forum using this plugin. This plugin displays the number of viewers next to forum, blog and social group channels.
Note that the counts do not update in real-time. It only updates on page load.
Instructions:
Translation:
To translate "x viewing" phrase, translate the "x_viewing" phrase variable in the Phrase Manager.
CSS Customization: [Updated on 8/28/2023 for vB6 compatibility]
In one of previous vB upgrades, vB made the forum title display in its own line causing the viewer counter to move to the next line. To fix this, add the below custom CSS in css_additional.css template in each of the active theme you are using:
Code:.forum-list-container .forum-item .cell-forum > .forum-wrapper > .forum-info > .forum-title { --margin-channel-icon: 0; display: inline-block; width: auto; }
Compatibility:- Compatible with vB5 and 6 (self-hosted)
- Not compatible with vBCloud.
- Made "x Viewing" phrase to be translated using the existing "x_viewing" phrase variable in the Phrase Manager.
- Fixed PHP errors in the mod template that occurred in some vB setups. Thanks to ABDURHMAN for reporting this issue.
- Initial version.
Price 1:
$15 (with vbmods.rocks branding in the footer)
Price 2:
$40 ($15 base price + $25 branding-free)
I tried it. It didn't work. I have emailed you my login details for my 3 websites so that you can take a look.Originally posted by DOSO View Post
Reply to TikTok BBCodeby flohseHello Glenn,
embedded TikTok videos don't play anymore. Can you please check and problably provide a fix? I have also checked this against...Yesterday, 12:36 PM -
by MitchGlenn, does this mod affect AI at all? Is AI still able to search the site and provide the same information as sites without the mod?
TYYesterday, 12:27 PM -
Reply to Auto-Embed Videos for vB5 and vB6by daria22Thanks for the update, Glenn. Good to know the mod still adds value alongside vB 6.2.2's native embedding, especially for Facebook Reels. I'll keep it...Yesterday, 03:01 AM
