Showing the number of viewers next to forum channels is a basic forum functionality but this is missing in vBulletin 5 and 6 by default. Worry no more as you can have this functionality in your vBulletin forum using this plugin. This plugin displays the number of viewers next to forum, blog and social group channels.
Note that the counts do not update in real-time. It only updates on page load.
Instructions:
Translation:
To translate "x viewing" phrase, translate the "x_viewing" phrase variable in the Phrase Manager.
CSS Customization: [Updated on 8/28/2023 for vB6 compatibility]
In one of previous vB upgrades, vB made the forum title display in its own line causing the viewer counter to move to the next line. To fix this, add the below custom CSS in css_additional.css template in each of the active theme you are using:
v1.2
- Fixed compatibility with vB 6.2.1.
- Made "x Viewing" phrase to be translated using the existing "x_viewing" phrase variable in the Phrase Manager.
- Fixed PHP errors in the mod template that occurred in some vB setups. Thanks to ABDURHMAN for reporting this issue.
- Initial version.
Price 1:
$15 (with vbmods.rocks branding in the footer)
Price 2:
$40 ($15 base price + $25 branding-free)
Instructions:
Translation:
.forum-list-container .forum-item .cell-forum > .forum-wrapper > .forum-info > .forum-title {
--margin-channel-icon: 0;
display: inline-block;
width: auto;
- Compatible with vB5 and 6 (self-hosted)
- Not compatible with vBCloud.
v1.2
- Initial version.
Price 1:
Price 2:
