VB Update 5.6.6 breaks username if "vbcards" are selected...
Quote Selected Text
It comes up like this now since 5.6.6
"Find all postsView Profile"Originally posted by Find all postsView ProfileDougInAustinIf you remove the steering wheel
New plugin version 1.1 uploaded in the first post. When uploading the xml file, make sure to select Allow Overwrite > Yes. I have updated instructions in the first post to add this instruction.Originally posted by Mitch View PostIt comes up like this now since 5.6.6
I have also updated the plugin on this site. So it should also work now here. The quote in this post was done by highlighting the text.
Hi Mitch,
I have two questions then, as a reminder, I'm using VB cloud.
1. I was looking at my cloud installation and I can't apparently install products. This means I have to add the hook and template manually, right?
2. What's the difference between this version and the vb cloud version?
TIA
1) These are the Pro versions (paid) which work on vB5 and vB6:
vBCloud:
This mod is the vBCloud version of the free Quote Selected Text for self-download vB5 (https://vbmods.rocks/forum/vbulletin-5-modifications/vbulletin-5-products-and-extensions/177-quote-selected-text). Sometimes you only want to quote some text in a post instead of the entire post when replying. This modification allows users
Self-hosted version:
Sometimes you only want to quote a portion of a post instead of the entire post when replying. This modification allows users to easily do that. This plugin is very useful for forums that want to have more precise and relevant quotes in their threads. It helps users to avoid quoting unnecessary or irrelevant text and focus on
2) This free version only works on desktop while the Pro version works on desktop, tablets, mobile and other touch devices. The Pro version is more efficient than the free version in terms of page load performance as it only loads the mod on Topic pages where it is needed while the Free version loads the mod on all pages across the site. The paid and free versions were not created at the same time. The paid ones were only created about 6 years after the free one to implement improvements to the mod.
- Likes 2
You purchased the vBCloud version which is correct. This is the topic for the vBCloud version
Make sure you follow the instructions carefully including the creation of the template and the template hook.
Please post in that topic if you still encounter any issues.
Apologies, I'm an idiot.
Ignore what I said, I realized my mistake and it's working great!!!!!!!!!!!!!
Reply to vB5 Likes Summaryby ayjayefExcellent, thank-you Glenn.
I've added that into web.config and feel a lot better that colons are only allowed for /ajax/api calls.
I much...Yesterday, 02:56 AM -
Reply to vB5 Likes Summaryby glennrocksvbYou can keep that setting to allow for the colon character application-wide in the request path. And then add this URL Rewrite setting to reject request...07-04-2026, 02:08 PM
