I am able to reproduce the problem on a small screen size by using my Galaxy 7 Android. The names of the forums do not appear on the screen, so I suspect that they do not also on some other smaller resolutions.
The mod works in the Today's Posts search result page on my site here. Can you try going to that page using your phone?
I think you missed my last message, Glenn. I had the default module and the Search module that rocks on the page. For some reason the default module doesn't display the category names in mobile view on my android.
I never noticed the default module has category names. It might be new. I'm currently using 5.3.2 beta.
FYI. With the release of 5.3.4 which adds the channel name in search results, this mod is no longer needed. If you have this mod and are running 5.3.4 and up, you need to disable or uninstall this mod in AdminCP > Products > Hooks & Manage Products. It is named as "Add Channel Name in Search Result by vBMods.rocks".
On a page where I added a search module (topic view) the channels are not shown.
But I had to deactivate your mod because on the "normal" searches, the channels were shown twice
I didn't realize they didn't add channel name in Search module Topic view. I'll fix the mod to not add channel name in Search Results so that you can use it in Search module Topic view.
Is this mod available for 5.7.5? It doesn't look like it was ever implemented by the VB team, and we'd really like to show the channel in our 'latest activity' module on our home page.
