DISCLAIMER: You must make backups before attempting this. According to the developer of the Xenforo Impex module it works on any version of Xenforo that is in the range of 1.5.x. It worked for me on 1.5.12 Do not blindly attempt this without creating and keeping available backups. Also monitor the PHP version your on and make sure it's compatible with Impex. If it's not then don't bother trying it.
This is a simple tutorial on how to successfully import a board from Xenforo to vBulletin. More than likely this will always work as long as your Xenforo board is on Xenforo 1.5.x
I will also mention the process is similar to any other impex import however you need to delete all the polls in the source database. It is required in order for this to work. If you have a larger board this can be an issue. However if you are able to delete polls this won't be a problem.
Okay first you will need to download impex which can be found here:
http://www.vbulletin.org/forum/showt...ighlight=impex
Then you will need to download the impex module created from this third party developer
http://www.vbulletin.org/forum/showt...=Xenforo+Impex
Now edit ImpExConfig.php with the proper database details. Pick your passcode and change the impex folder to "impex".
Now download and install vBulletin 4.2.2
Make sure it's not the newer versions but actually 4.2.2 as this is the version number to use on vbulletin.org
Upload the impex folder to the directory your vBulletin files are in.
Now in order for the 'Import' button to show at the top in the admincp you will need to move the file named cpnav_impex found in the impex folder to > includes/xml
Next get your Xenforo Impex module files and upload the Xenforo folder to the systems folder in impex.
Now when you login to your admincp the import option will be available.
Before you begin with this I need to make one thing clear. It works but there is one thing it throws an error for. That's polls. In order to get this to work you will need to delete all the polls on your forum. If there's a single poll on your forum it WILL NOT work. If your forum has no polls then this will work.
Now simply run the modules and they will all work without an issue. After this all you need to do is update forum information, update thread information, update post counts, update user names, fix broken user profiles... etc. Pretty much just running the required general update tools.
Now your board is imported. You will need to merge the imported admin account with your own admin account. It should have imported_ before your username. Go to merge users and select you want to merge the imported user with your actual admin username. Merge them and then you are finished.
After this you can now upgrade to vBulletin 5 Connect. Make sure everything is like you wanted, take extra backups, and than proceed to upgrade to vBulletin 5 Connect.
I know this will help a lot of people and I hope it does. This worked for me on 1.5.12 without issue. Of course my board was very small and had less than 100 posts. I still know it would work on a larger board. I wasn't able to import avatars because I didn't set the directory path up but I'm sure that would work too if you did it.
