c0sie, are you using static image ad? Or dynamic ads something like AdSense?
How to put ads after first post in a thread on vB5 without using plugins
Hi Glenn
hope you are having a good day
I
i know this is an old thread but I implemented it when you first shared it although it’s been turned off for a while I tried it again recently but although it worked on some devices on others it put the ad in the first post, ignoring the CSS to move it below I guess.
Also I can’t seem to change the option for who to show it to to, no usergroup can be selected in the ad module.
Do you think it’s a conflict in vb6?
Is it something that could be fixed to work in v6?
You don't need this mod anymore in vB6. vB6 has a new feature that can do the same:
<p>Using a custom template with your ad unit (i.e. Google Ad Sense code) and a template hook allows you to easily insert ads between posts.</p> <h2>Creating your template</h2> <ol> <li>In the admincp go to Styles -> Style Manager</li> <li>On the Choose Action... drop down,
Thanks Glenn, I tried that but it doesn’t work, saving the template shows an error, I mentioned it in the comments, there is also someone else having the same problem.
Wayne will hopefully update when he has the time.
Hi Glenn, unfortunately it wont work that way if you want the ads only to show up below the very first post (not the answers).Originally posted by glennrocksvb View PostYou don't need this mod anymore in vB6. vB6 has a new feature that can do the same:
Is there any way to fix that?
Problem source: https://forum.vbulletin.com/forum/vb...e-side-of-post
