Understood, thanks.
vB5 AutoLinker
Hi Glenn,
Is the 50$ price tag branding free?
Has this product been tested to Amazon affiliates. I have never used my Amazon Affiliate account and I want to hyperlink certain keywords throughout the site to an Amazon product.
Thanks,
William
Yes it is branding free.
Yes it works with Amazon affiliates or any other affiliates. This mod is installed here and some autolinks on this site are Amazon affiliate links.
Question, is the desired keyword capital or case sensitive? Basically, I'm adding the keyword (Bible, url) to Amazon in the auto linker. Do I need to create two different ones for Bible and bible?
William
Way to go Glenn! Love this product. I have added links to keyword "bible" to Amazon affiliate program. If anyone wants to check it out then look no further than here: https://www.christforums.org/forum/c...standard-bible
I plan to put a ton of keyword links to various books.
Thanks again,
William
Hi Glenn,
First of all, wonderful mod!
When using words containing an ' all the links do not work anymore. If I remove the ' everything works as it should. Could you please advise if there is a way to get this working?
Thanks,
Rob
Fleiding It's working here. I temporarily added the word "It's" to be autolinked and it's working.Last edited by glennrocksvb; 01-07-2018, 08:01 PM.
glennrocksvb I switched the language from Dutch to English and back again and now it appears to be working.
Hi Glenn,
It appears that words containing é doesn't work either for me. Could you please check?
Thanks,
Rob
Thanks. I see "Unexpected token ," JS error. Will investigate. You can revert now.
The JS error is caused by PHP not being able to encode the string with accented characters as JSON object. I don't have a solution at this time. Will keep you posted.
More than one word should work. Make sure you don't have 2 spaces between words.
I'm interested in this mod, but have a few questions.
1. Does the admin create a menu of words that would be auto linked?
2. If question 1 is true, what happens when a word is removed from the menu?
Basically curious exactly how it works.
Thanks for your interest and questions.
1. Yes in AdminCP.
2. The word will not be autolinked anymore.
Only configured words/phrases in the AutoLinker settings in AdminCP will be autolinked. If you add/remove words in the settings, then the autolinked words on the posts will be updated (added or removed) accordingly.
