Display Status Update in Postbit
    There should be an <li> tag before that code. Add the class in that tag.
    I would recommend using my free custom profile fields in postbit mod instead. It's easier to configure in AdminCP settings and you don't need to modify any existing templates.
      Please disregard Glenn, I figured it out:
      <ul class="b-userinfo__additional-info">
      Thank you very much!
      William
      Should be in <li> tag not <ul>. Please see post #16.
        Hi Glenn,
        How do I put the status update above "Join Date" using your custom profile fields mod? When it's under "Send PM", it turns the quote text into a link for me. Then again I'm gonna check the code for the Send PM button right now and see if there's a missing closing bracket.
        * Update: My code was fine.
          Originally posted by Calamity View Post
          Hi Glenn,
          I posted the CSS to put the status on top of Join Date in post #13 of this thread.
            I've done the CSS part, but was a bit confused at the first step. When I tried adding it like you said, it didn't work.
              You have omitted the closing </li> tag for the Send PM. That's causing the next <li> which is the status to be a link.
                Should be:
                Send PM[COLOR=#FF0000]</li>[/COLOR]
                  That would be my amazing HTML skills in a nutshell. :P
                  Don't worry, I'm working on it...
                    Should be:
                    Ah! Thanks! I tried that, but for some reason the status itself is still a link to the same as Send PM.
                      The closing </a> tag is missing.
                      Send PM[COLOR=#FF0000]</a>[/COLOR]</li>
                        Embarrassing. Thank you so much, though
                          FYI. I updated the CSS in post #13.
                            Great! Looks like I have to update my StyleVars, because mine has a transparent background?
                              No, I added more custom CSS for that in this site and I haven't added that as part of the mod yet.
                              I have updated post #13 again. But that still doesn't include the styling for the status itself.
                            • Calamity
                              That looks a lot better. Might customize it some more later.
                            #29
                            "AdminCP > Products & Hooks > Manage Products > [Add/Import Product]."
                            Products & Hooks and on doesnt show up in my control panel? any idea where this has been moved to?
                              Are you on vBCloud? Products and hooks are not allowed in vBCloud.
                            #30
Name:	Screen Shot 2017-03-20 at 21.37.38.png
                            How do I get exactly the way it is for you (see the above image). Please give step by step guidelines. Really appreciate your work.
