Stuck "Working..." Indicator Fix
    Free Mod Stuck "Working..." Indicator Fix
    There is a known intermittent issue on vBulletin 5.x (as of this writing) wherein after submitting a post, the new post is saved but the yellow "Working..." indicator is stuck and the new post is never displayed unless you reload the page. This product fixes that bug.
    Download the file, uncompress it and then upload the XML file in AdminCP > Products & Hooks > Manage Products.
    So my problem is related to this... I can have two tabs open. post on one tab... go to the other... and its there after a refresh... but the original tab still has working sitting there.... so there is no post slow... its the working is hung up for a long time? Any ideas on this? I have installed this mod, as well and its the same... even down graded from 5.2.5 to 5.2.4 PL2 same result.
      thank you guys !!
        Originally posted by kambing99 View Post
        thank you guys !!
        No problem. Welcome to the forums! Hope you find more useful mods here.
          thans it help to me
            thanx
              Thanks
                Works like a charm. Thank you.
                (Still experiencing the stuck "working" indicator for articles though. Seems odd since it seems to have fixed other channels.)
                Last edited by therealcw; 06-19-2017, 06:05 AM. Reason: Still have an issue with posting articles.
                  Thanks a lot. This bug was a pain in the *** Thanks a lot!
                    thanks
                      Thanks very much, works fine!!!!
                        Hello,
                        I have a problem that when i send a new topic i get a popup window with this error even if the topic going home I find it saved
                        https://imgur.com/a/7tGKY
                        I wanted to know if this product solves this error.
                        Thanks friends
                          That's a different issue. You're using a custom theme. Does the error also occur on default style ?
                            Hello Glenn, good evening,
                            I just tried on the default theme and gives me the same error, yes my style is a custom theme, is Quarto Dark Cyan, I can not understand why it gives me this problem
                              Can you get the ajax response text from the create-content api call in the browser dev tools? If you don't know how to do this, then I'd need test account on your forum for me to check.
                              • kipinny
                                looking forward to trying some mods
                                by kipinny
                                very nice site i am a old site owner use to run vb 3x versions just purchased vbullitin 6 and i want to build a sweet site and hoping for some grea mods...
                                07-16-2026, 04:03 PM
                              • daria22
                                Daria introduction
                                by daria22
                                My name is Daria. I'm jumping into vBulletin to build a community for my gardening hobby.
                                I'm hoping to learn more about vBulletin as I recently...
                                07-16-2026, 12:22 PM
                              • Chunk
                                Chunk Introduction
                                by Chunk
                                Hello!
                                My name is Chunk (nickname). Im current graduated from my local college for Web Development. Today I will be exploring vBulletin...
                                07-11-2026, 06:08 AM
