In some cases you need to clear system cache in AdminCP once in a while to reduce the size of cache tables. Worry no more! This vBulletin 5 cron plugin runs scheduled task to automate the manual clearing of system cache using Maintenance > Clear System Cache in AdminCP.
Once this plugin is installed, "Clear System Cache" task will appear in the Scheduled Task Manager and will run according to the schedule. By default, the task runs every hour on the hour. Like in any other task, you can edit the schedule if you want.
Price 1:
$10 (with vbmods.rocks branding in the footer)
Price 2:
$35 ($10 base price + $25 branding-free)
- Compatible with vB5 and 6 (self-hosted)
- Not compatible with vBCloud.
Price 1:
Price 2:
