Solved this by setting the Unregistered usergroup to not be able to view channels; that seems to make it so they can't view any of the pages, which is what I wanted.
I have another question, also about the missing User Listing Options page. I want to be able to display custom profile fields in the Member List. Like, this thread https://www.vbulletin.com/forum/foru...on-member-list suggests that you're supposed to be able to set your custom profile fields to be visible in the member list via the User Listing Options page. Is that no longer possible?
In the User Profile Field Manager page, I can set any of the fields to be shown in the Member List, but it doesn't have any effect. The Member List doesn't show any of the fields I've specified should be visible there. What am I missing?
Even the non-custom profile fields seem not to show up in the Member List if I configure them to, though: Biography, Location, Interests, etc. Is that a bug?
Ah, okay. So (sorry, I'm pretty new to vB development) what you're saying is that vB5 is a major rewrite and they haven't fully implemented all the features that were present in vB4 yet?
That would explain why you can specify profile fields as "Show on Members List" but that doesn't actually have any effect, I guess?
Correct. And some old settings have not been totally removed. And also some vB3/vB4 features may never be implemented or had been implemented differently.
Good Day Glenn!! I implemented the above hook. My font style and size changed when typing a reply to a post. Not sure if it also changed in other instances....
