Fortunately I have never had to restore a site from an update, back to the previous version. So my question is, what is the best method of procedure for doing this?
How to restore
Did you backup the database prior to upgrade?Helpful? Donate. Thanks!
Just restore the backup to the db server.Helpful? Donate. Thanks!
I understand that part. What about the new script files sitting in the html directory? Do I reinstall the previous version and run the install script?
Comment on Topic Starter Ribbon for vBCloudby glennrocksvbThanks for confirming the fix works.Today, 08:20 AM
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbI have updated the template code in the first post. Please try it again.Today, 06:38 AM
