Is this a vBulletin issue?
    Not a browser issue. I run Thunderbird 141.0 (64-bit) on my iMac (running macOS Big Sur Version 11.7.10 (20G1427).
    Thunderbird displays emails with graphics and active hyperlinks just fine, except for New User email notifications I receive from our forum. Those emails, even though they contain html entries, don't display as hyperlinks, and nothing I can find in Thunderbird settings accounts for this, so I'm making an assumption that it's how vBulletin constructs the content that it then emails? Ideas? Suggestions?
Name:	Screen Shot 2025-08-06 at 2.47.12 PM.png
    These emails do display with active hyperlinks if I view them in Apples email client (Mail) that comes with Big Sur, or if I view them in my Gmail account.
    Some (most) email clients automatically render plain text URLs as links. I guess Thunderbird is not one of them. To ensure all the URLs are displayed as links, you need to update the email templates and update the URLs with <a> hyperlink tags.
    Initially vB5 didn't support HTML emails. But starting vB 5.6.9, it supported HTML in emails. But it required admins to manually update the email templates to add hyperlinks if you have custom translations for these phrases. I guess you didn't update the templates.
    Here's the release notes for your reference and refer to the "HTML Support for Outgoing Emails​" section.
    &lt;p&gt;vBulletin 5.6.9 is available for download. vBulletin Cloud customers will be upgraded automatically.&lt;/p&gt; &lt;h2&gt;Front End Changes&lt;/h2&gt; &lt;h3&gt;Copy and Paste Image Uploads&lt;/h3&gt; &lt;p&gt;Users can now use Copy and Paste to upload images into their posts. Users should be warned that image sizes may
      Thank you. I’ll review the template and make the adjustments.
        This is what we have now.
        Click image for larger version  Name:	Screen Shot 2025-08-06 at 6.24.49 PM.png Views:	0 Size:	131.4 KB ID:	32834
        Do I just need to replace the {number} with the {variablename} as shown?
          Any placeholder for links should be replaced with <a> tag. In this case, it's the {3} placeholder that holds the URL for the profile. So you'll replace it with:
          <a href="{3}">{3}</a>
          If you also want the IP address to be a link, then it should be replace with:
          <a href="https://ipinfo.io/{6}">https://ipinfo.io/{6}</a>
          • Snowhog
            Thank you.
          Ignore.
