deleteing from text table
    Those [FONT], [SIZE] and [COLOR] BBCode tags will be replaced with their corresponding HTML tags when displayed in the posts. The CSS solution I posted should still work in resetting those styles to default/inherited style.
    But if you insist on doing the SQL solution over CSS solution, you'll likely need to use REGEXP_REPLACE() which is not simple to do.
      this's as you said.
      And here's the result in the post (Sorry it's arabic language
      Is this correct?
      UPDATE `text` SET `rawtext` = REGEXP_REPLACE(`rawtext`, '\\[font=[a-zA-Z0-9 ]+\\]', '')
      UPDATE `text`SET `rawtext` = REGEXP_REPLACE(`rawtext`, '\\[color=#[a-fA-F0-9]{6}]\\]','');
        It looks like the [color] BBCode tags are not evaluated to its <font> HTML equivalent with color attribute. The CSS will not be applied in that case as it only works with HTML tags not BBCode tags.
        I notice that the [color] BBCode tags are invalid/incorrect. Was it caused of the SQL Update query you executed?
          This's why I decided to remove any old tag there, even if manually.
          Regards.
            I'm not an expert in regular expressions but try doing a SELECT first and see if any records match and then use the pattern in the UPDATE later.
            SELECT * FROM text WHERE rawtext REGEXP '\\[font .+\\]';
            This is a safer way to test the REGEXP pattern first without doing the UPDATE yet.
              Example:
              [FONT=Simplified Arabic] = 90 matches
              Here's the result​
                Try this:
                SELECT * FROM text WHERE rawtext REGEXP '\\[font\\s|font\=.+\\]';​
                This should cover both [FONT COLOR=XXXXXX] and [FONT=XXXX]
                  Btw, I'm not responsible if your data gets messed up with the solutions I'm posting. I recommend doing this in a copy of the database rather than the live database.
                    I updated the REGEXP pattern used. See it in the query below.
                    I also updated the SELECT query to show the preview of the updated rawtext so you can see if the replacements to be done look good.
                    SELECT rawtext as `rawtext before`, REGEXP_REPLACE(rawtext, '\\[font\\s.+\\]|\\[font\=.+\\]', '') as `rawtext after` FROM text WHERE rawtext REGEXP '\\[font\\s.+\\]|\\[font\=.+\\]';
                      See sample results from my test database:
                        Oopps! There's a bug in the query. It also deletes the text between the [FONT] tags.
                        This is complicated to fix. It would require a lot of trials and errors. There are a lot of BBCode variations to cover. You need to find the different variations used in the database so you can limit/simplify the REGEXP patterns to use in the query and not try to cover all possible variations.
                      #26
                      Try this:
                      Here's the result
                        Click image for larger version  Name:	image.png Views:	6 Size:	120.5 KB ID:	27834
                        This one says:
                        First total is 15544
                        Second is 4041​
                          The SELECT query I provided has a bug in it as I mentioned in the comments in post #25
                            Regards.
                            Why removing, you would corrupt your form styling, i used to do this in very simple way, and it just takes a few seconds for thousands of fields to be replaced.
                            update text set rawtext =
                            replace(rawtext,'=12px','18px');​
